Case Mod - Complete ⭐ BORD3RLANDS MOD *HW LEGEND MODDING TEAM*
Discussion in 'Project Logs' started by pccustom, 1 Feb 2020.
  1. pccustom
    pccustom Modder
    12 Jul 2017
    and here I am with another mod coming soon, I can tell you that the main sponsor is sharkoon who generously sent me this material
    here the stuff!
    CASE REV200 sharkoon ATX
    https://it.sharkoon.com/product/28160
    PSU SHARK SILENT STORM COOL ZERO 650W
    https://it.sharkoon.com/product/SilStorCool0
    SHARKBLADE STRIPS RGB
    https://it.sharkoon.com/product/26883
    TASTIERA GAMING SKILLER MECH SGK3 red
    https://it.sharkoon.com/product/SKILLER MECH SGK3
    MOUSE GAMING SKILLER SGM2
    https://it.sharkoon.com/product/21536
    CUFFIE GAMING SKILLER SGH3
    https://it.sharkoon.com/product/20713
    VENTOLE RGB SHARKOON SHARKBLADE RGB
    https://it.sharkoon.com/product/26876
    I am waiting for other material that I will post soon I can say that it will be an AMD mod ... there will be fun​
    TerHorstCustoms likes this.
  2. TerHorstCustoms
    TerHorstCustoms Minimodder
    29 Jan 2020
    Looking good so far. Kinda curious what hardware will be used in the buid :)
    pccustom likes this.
  3. pccustom
    pccustom Modder
    12 Jul 2017
    Hi guys it time to work!!!
    tolgo la partatia del vetro temperato.v
    the beautiful sharkoon shark blade fans supplied with the case 5
    via tutto il testo vernicero altre parti separatamente.
    I remove the PSU cover and I will try it again in this way it will be easier to paint it.
    naked...
    let's move on to the front panel, it has 3 tempered glasses, the central one is fixed with screws on rubber washers as it should be
    very easy to disassemble.
    the upper and lower ones are fixed with double-sided tape have only an aesthetic function, nothing functional to avoid breaking them, I heat the surfaces with a hairdryer, a hot gun would be too much perhaps and I would risk deforming the plastic parts, this will make the adhesive softer and easier to remove, by not doing this I would risk breaking the glass.
    now, surface treatment and first painting I limit myself only to scouring and cleaning with alcohol to degrease.
  4. pccustom
    pccustom Modder
    12 Jul 2017
    Painting case components .. my intend to transform this mod into a work of art, I also take care of the hidden details.
  5. pccustom
    pccustom Modder
    12 Jul 2017
    to create an erosion effect I use a fine steel scouring pad, this will allow me to opacify the paint to give it an opaque and revised effect ready for painting in acrylic color.
    I made the triangular plexiglass panels again because the original ones are in tempered glass and cannot be painted.
    smontaggio del resto del case fatto a pezzi.
  6. pccustom
    pccustom Modder
    12 Jul 2017
    surface processing, I took care not to use PRIMER in order to facilitate the peeling for the details
    censored_Prometheus_ likes this.
  7. pccustom
    pccustom Modder
    12 Jul 2017
    surface treatment and decoration
    the paint must be opaque using a steel sponge
    I use acrylic colors applied with a sponge first the black and then the silver (in a very small dose)
    this is the effect
  8. pccustom
    pccustom Modder
    12 Jul 2017
    Riassembling with rivets..
    Arboreal and arduum like this.
  9. pccustom
    pccustom Modder
    12 Jul 2017
    Processing of the side panel which provides the logo with leds rgb
    Preparation of stencils prepared with silhouette studio, decomposition of the logo
    1 the! A! red which will be worked with celophan for food rolled to give the effect marble / wear and get as close as possible to the original logo
    2 areas in black which will be painted later
    the dabbing creates this interesting effect another light layer of red will be applied.
    next phase of the RGB logo that will be applied on the bulkhead.
  10. kim
    kim hardware addict
    10 Jan 2016
    great art :thumb:
  11. pccustom
    pccustom Modder
    12 Jul 2017
    side panel with BL3 RGB logo
  12. dreps
    dreps Minimodder
    3 Oct 2012
    damn that's pretty neat mate!
  13. pccustom
    pccustom Modder
    12 Jul 2017
    my intention is also to modify the motherboard to do this I have seen a number of guides for how to make a cover called "armor"
    first I download a photodelleìa motherboard from the manufacturer and with photoshop I bring it in full scale, after which by opening it in adobe illustrator I get the areas to be cut
    I got the mold outliner cu adhesive paper (I had a little to recycle) and I prepare the piece of acrylic (thickness 2 mm)
    cut, I noticed that my motor saw did not cut well the cut was inaccurate and I decided to open it to check ....
    and here's the surprise, years of braying on acrylic and tiny pieces have clogged the gears, I recommend to all modders who use it intensively to do a cleaning once a year
    everything is gone now
    finishing, the areas needed continuous checks and adjustments.
    now I stop here I wait for the deep cool AIO to check the socket area if it needs further adjustments but I would say that we are there.
  14. Cheapskate
    13 May 2007
    The page opened with just the pic of the blank base of the logo, and I was like, WTF ? :lol:
    Note to self: Dremel are too cheap to have a sealed gearbox. With all the Dremels I've killed it's no surprise.
  15. pccustom
    pccustom Modder
    12 Jul 2017
    I think the page is ok...
  16. Cheapskate
    13 May 2007
    I meant I saw plate and thought you were making a dong :lol:
    Jean R built likes this.
  17. Jangalit
    Jangalit What's a Dremel?
    28 Feb 2020
    wow I loce the color scheme mixed witht the rusty look
  18. pccustom
    pccustom Modder
    12 Jul 2017
    well ... the original feet of the case are not good they are too elegant you need something more tough that is in theme with the mod
    I decide to build them, but I'm not going to make six usual feet.
    I start with an aluminum strip ..
    they are composed of two parts, the top and the bottom, with two pins on the sides, in this way the case can settle itself, and there will be no problem
    that it is unstable rubber pads will do the rest.
    painted with anthracite gray, I do not put primer, the paint must come off easily to give a wear effect in theme with the mod.
    wear effect with steel wool ..
    lat first part it is fixed with rivets to the case ..
    final results.
  19. pccustom
    pccustom Modder
    12 Jul 2017
    today another sponsor has joined the mod
    I'm talking about deep cool with its fantastic AIO gamer storm captain 240 PRO V2
    enjoy this unboxing ...
    [VIDEO]
  20. pccustom
    pccustom Modder
    12 Jul 2017
    today I focus on the internal panels perhaps from the noin photos you understand well but later everything will be clarified better
    internally I will put 2 panels one top folded 5 times
    and a lower one folded in a shield way on the sides, these will serve to put the logos as well as giving a note of color more and some logo as well as filling spaces that remaining empty would not have a nice effect.
    questo è il pannello superiore interno
    this the lower one
    paint color anthracite light gray and opaque with steel wool.
