Case Mod - Complete ⭐ BORD3RLANDS MOD *HW LEGEND MODDING TEAM*
Discussion in 'Project Logs' started by pccustom, 1 Feb 2020.
  1. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    Painting is great. The idea with feet is super, but make rubber pads for legs. They will reduce vibration and protecting the table surface. :dremel:
    pccustom likes this.
  2. pccustom
    pccustom Multimodder
    12 Jul 2017
    yes I think the same I'll do that after the final assembly..
  3. pccustom
    12 Jul 2017
    Well guys. Today we post the progress of the works. I proceed with the covers made previously, that is the upper and lower ones. After applying the matt anthracite paint I go with the graphics and wear. Upper door panel:
    Side panel with logo:
    I also drive myself with a file obviously all piloted ...
    Silver acrylic application on the cracks:
    roceed with the rest
    Case logo and removable top panel:
    Graphic application and metal wear effect:
    censored_Prometheus_ likes this.
  4. pccustom
    12 Jul 2017
    panels assembly
    today a big surprise came the inno3d video card ......
    unboxing soon ...
  5. Vault-Tec
    30 Aug 2015
    Amazing work man !
  6. pccustom
    12 Jul 2017
    new sponsor join to the mod ram and ssd from OCPC
  7. pccustom
    12 Jul 2017
    it's time to pick up the cover of the motherboard that I was preparing, I was waiting for the AIO of the deepcool to see if I had to do further measures but luckily there is no need.
    I start immediately with a nice painted matt white.
    ora procedo con la grafica rigorosamente MSI..
    I take advantage of it and I place the AMD processor a nice RYZEN 5 3500G arrived from my sponsor PC HUNTER
    now I proceed to the realization of the cover of the aio panel of the motherboard it is really bad to leave it uncovered
    it is 3 mm thick acrylic.
    anthracite gray paintwork
    after having applied the motherboard model, I proceed with the wear effect, the same procedure used for the internal panels
    or opacification with steel wool and file engraving.
    acrylic silver application
    temporary assembly.
  8. censored_Prometheus_
    26 Mar 2019
    Looks super! :dremel::clap::clap::clap:
  9. pccustom
    12 Jul 2017
    mounting the motherboard on the pc and memories.
    it is necessary to fix the motherboard with spacers these vary according to the height of the cover, for forcing I always keep these screws when I get rid of an old case they can always be useful, on being fixed the cover.
    For those interested in creating one I invite you to take a look at my video at the tips and tricks section of my youtube channel
    since I am also mounting the felt pads under the feet to cushion vibrations ...
    it's time to fix the video card INNO3D 2080 SUPER TWIN X2 OC fantastic !!!
  10. BigShadow
    BigShadow What's a Dremel?
    10 Feb 2020
    Man, your attention to the detail is incredible, looks awesome the build
  11. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Amazing, work mate :)
  12. pccustom
    12 Jul 2017
    DEEPCOOL logo
    bulkhead tempered glass etching, a well-established practice
    my inseparable friend ...
  13. pccustom
    12 Jul 2017
    retouching the front panel, it was too empty I add some elements I took inspiration from the worn fl4k armor.
    support panels these will give a more badass look
    final assembly
    ivory2k19 and Jean R built like this.
  14. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    The extra's to the front panel worked perfect, in fact the whole mod is damm perfect !
    Ive never had the skills or patience to get the aged look right, Much respect :rock:
  15. pccustom
    12 Jul 2017
    thank you!
  16. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    You sir are a wizard with them skills.
  17. pccustom
    12 Jul 2017
    The time has come to modify the fantastic INNO3D RTX 2080 SUPER TWIN X2 OC video card
    I build a backplate to be applied on the back leaving space for the connectors and logos, I remember that this card will be positioned vertically as provided by this sharkoon case I limit myself to using the same processing done for the panels so I will not post photos of the detailed processing I would not like to repeat myself .
    the power in my hand... hahahah :)
    video!!!
  18. pccustom
    12 Jul 2017
    we got to the final step here are the final photos of my latest mod I hope you likedas to make it
    a heartfelt thanks to all my sponsors who allowed this mod, sharkoon, inno3d, msi, ocpc, deepcool, hardwire cable, pc hunter, hwlegend modding
    arduum and censored_Prometheus_ like this.
  19. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Excellent Smithers :naughty:
  20. MADPC
    MADPC Minimodder
    10 May 2020
    I think this mod is the most realistic I've ever seen! the wear effect is real not cartoon like made in other mods, I prefer it, really good!
