Graphics bored so modded evga 570 with h40
Discussion in 'Hardware' started by jizwizard, 28 Feb 2012.
  1. jizwizard
    jizwizard Modder
    24 Dec 2010
    as title suggests i was bored after work and i had a spare corsair h40 (yes the baby of the bunch) doing nothing. decided to strap it to one of my 570's for a laugh see what the temps would be like.
    not bad really. was tested on extreme burn in for 5 mins. temps platoed out at about 60c. considering with the standard cooling it hits 80c+ not bad at all. would i suggest doing this? if your on a really tight bugget yes i would as the gains are pretty good. will i be staying like this? no full watercool for me, but there are gains to be had by doing this. not bad for £30
    Sloth, Picarro, Guest-44432 and 2 others like this.
  2. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Lol nicely done, I would have expected worse temps tbh
  3. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    naice
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    Rep'd for ballsiness
  5. feathers
    feathers Minimodder
    11 Apr 2009
    20c drop is good for a 2 piece water loop sucking room air. My 560ti's were also hitting 80c on air and sounded awful. 45c max load in the heat of summer and 30c winter full load on liquid. Rad sits on window ledge sucking in outside air.
    I will be interested to see what temps u get when u go for a full liquid loop.
  6. JoeK
    JoeK Minimodder
    24 Dec 2010
    so there's no pump? just the rad and tubes?
  7. docodine
    10 Feb 2007
    Pump is attached to the waterblock on the H40 iirc
  8. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Any chance of any more pics showing how you attached it to the GPU?
  9. jizwizard
    jizwizard Modder
    24 Dec 2010
    Will post up tomorrow mate. Took 5 mins lol
  10. flame696
    15 May 2009
    i want to see this as i could do something like this with my gtx 580
  11. feathers
    feathers Minimodder
    11 Apr 2009
    Isn't it a real shame there is no standard agreed for heatsinks to allow switching to liquid. DFI made some mobos u could unscrew the top half of the heatsink and fit a waterblock. Foxconn blackops U could change the top part of the NB block to make it air, liquid or LN2.
    They could agree a standard by which a GPU could be switched to liquid easily. Hybrid heatsinks. Remember the OCZ liquid cooled ram? It had air heatsink and was also a waterblock.
    It's a shame because we are forced to fit rather expensive full cover waterblocks to GPU's or GPU core only blocks which usually means faffing about with mosfet and ram heatsinks.
  12. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    And the origional Rampage Extreme had that too...
  13. JoeK
    JoeK Minimodder
    24 Dec 2010
    oh, i have a h50 and the pump is massive, didn't think the h40 was that small.
  14. feathers
    feathers Minimodder
    11 Apr 2009
    Aha!
    My old Asus Max extreme had it. The waterblock/heatsink was utter crap though.
  15. feathers
    feathers Minimodder
    11 Apr 2009
    Jizwizard:
    It's just occured to me that the H40 you modded of course has the pump in the CPU block... It's quite a bulky block but u appear to have the original heatsink assembly on the GPU... Does the central part of the GPU heatsink detach?
  16. jizwizard
    jizwizard Modder
    24 Dec 2010
    Heat sink and fan have been removed, but I left the fan shroud on. Dismantled it now but will post some pics tonight on how to do this. Piece of cake to do and only took 5 mins
  17. GeorgeStorm
    16 Dec 2008
    So how hot are the memory chips/mosfets getting?
  18. Guest-44432
    Guest-44432 Guest
    I own both of those boards. BTW the Formula came in 2 models. SE and Non SE. 1 had the waterblock, the other didn't.
    My wallet still hurts from forking out £220 for '2GB OCZ 1600Mhz DDR3' on top of the £220 Maximus Extreme...
    EDIT; On topic! Nice work Jizwizard! Have a Rep Bomb from me. ;)
  19. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    I imagine you'll leave a few layers of skin if you ever touch them. This is why you really need a GPU block designed for that specific card, because unlike a CPU where everything around the CPU itslf can be cooled quite easily with case airflow and the basic heatsinks, a GPU you need direct airflow over the whole lot or it'll fry after a while.
    I wish someone made an all-in-1 WC for GPU's like corsiar and Antec do for CPU's. Im not dedicated enough to build a whole WC system, but i would be seriously tempted to buy an H60-esque cooler if it had a way of cooling the memory and mosfets as well.
  20. feathers
    feathers Minimodder
    11 Apr 2009
    I was lucky with my MSI 560Ti's because the air cooler they came with only cooled the GPU core. It did not touch the mosfets or ram and thus I am able to cool those parts with a 120mm fan on the side of the GPU's.
    The bigger GPU's have heatsink cooling of PWM and GDDR so you would be forced to add mosfet and ram heatsinks. The mosfets can be a problem to add sinks to because they are small and a mosfet heatsink will often cover several mosfets and if they are at different heights... contact will be bad.
