Build Advice Boxed PC's?
Discussion in 'Hardware' started by Faulk_Wulf, 14 Jan 2011.
  1. Faulk_Wulf
    Faulk_Wulf Internet Addict
    28 Mar 2006
    I have built my own computer before. Then I used a laptop. That died recently and I haven't followed pc specs for over a year but my demands haven't really increased any either. Im standing in a Wal-Mart and see all of these $300-700 pc's. My most advanced games are Arma 2 and CnC3. I would like to do CAD or SketchUp and such but beyond that and watching Netflix/media streaming that's it. I moved to console gaming except for mmo's. New tech just comes out too fast. My droid x obsoleted my laptop anyway. So what's my best bet? Big box retailer, e-tailer (Tiger/NewEgg) or self build still?
    Thanks.
  2. murraynt
    murraynt Modder
    6 Jun 2009
    Self build will always be the best. You are looking at quite a powerfull rig to play Arma 2.
    Whats your budget?
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    +1
  4. Kaaa
    Kaaa What's a Dremel?
    22 May 2010
    Definitely go self built, I bought a pre-built from pc world, regretted it since :sigh:
  5. Bloody_Pete
    11 Aug 2008
    Was that before you discovered the world of Bit-Tech?
  6. Kaaa
    22 May 2010
    Indeed, regretted it loads. Still, great to have found this place :D and the computer is/ was (gfx upgraded) fine, just paid over the odds for it :(
  7. Faulk_Wulf
    28 Mar 2006
    Well I assumed on putting a gpu in a boxed rig. I've been playing A2 on full low at 1024x768 so Im not too picky. Budget $500-700. I look at the reccomended hardware for budget pcs every month. If that's the best way to go ill just do that. I thought boxed might save me a few hundred was all. I don't know what socket is the best even anymore. 775? Is PCI-e still the best for gpu's? Too many RSS feeds, I just haven't kept up.
  8. bemused
    bemused What's a Dremel?
    9 Jan 2011
    Why don't you just look up the specs for the machine and see how much those parts would cost you? If it's cheaper yourself you could see what better components you could buy for the same cash.
  9. Bloody_Pete
    11 Aug 2008
    Just get the Gaming workhorse in the buyers guide :) 775 is nearly dead now. And how can a boxed one be cheaper if they have to pay someone to build it?
  10. murraynt
    murraynt Modder
    6 Jun 2009
    775 was the bees knees 3 years ago, then 1156 replaced it and since monday 1155 replaced that.
    If you can give some more info it would be great.
    What size hdd, Nice quite case? I'll tot one up for you.
  11. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    The thought of someone trying to play Arma 2 on a Wal-Mart PC is terrifying.
  12. fuus
    fuus Rocking All Year Christmas
    4 Dec 2010
    +1 Ph4ZeD, custom all the way :cool:
  13. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    It's the geeks version of watching paint dry.
  14. Pete J
    Pete J Employed scum
    28 Sep 2009
    It's one of those rare occasions where a great CPU (i5 2500k) and GPU (GTX 560) have pretty much come out at the same time.
    Okay, the 560 hasn't been released yet but it's slated for an end of January release. I would advise holding off until then - the resulting system could be such sweet value for money.
  15. kylesaisgone
    kylesaisgone What's a Dremel?
    23 Oct 2010
    Never ever buy a pre-built. There's so many reasons why. They use cheap components, you can't fix them if you want to keep your warranty, it's bundled with so much annoying software, etc. Companies cut so many corners by putting in cheap components, and your components will slowly die over time because of the domino effect of crappy components.
    It's far more advantageous for you to learn how to build your own, learn how the components work and go together, so when problems arise, you can fix them on your own.
  16. sp0rk
    sp0rk What's a Dremel?
    23 Aug 2010
    Edit: nevermind..
  17. jrs77
    jrs77 Modder
    17 Feb 2006
    The people giving advices for building a rig shouldn't forget about the fact, that you need to pay $150 for a copy of Windows 7 and another $150 for a LCD-screen ontop of the system you're going to build.
    But let's see what we can get for $700, if a retail-copy of Windows7 and a LCD-screen is allready there. And we won't talk about CPU and motherboard now, but only about the basics that are the same for all of them, shall we.
    RAM: 4GB DDR3 = $50
    HDD: 1x 500GB SATA = $40
    GPU: midrange = $150
    Case: cheap Antec 300 or the like = $50
    PSU: 500-600 Watts = $70
    That's around $350 allready, leaving us with another $350 to play with.
    A somewhat decent motherboard for either 1156, 1155 or AM3 is around $100, which would leave $150 for a CPU.
    Now, for the remaining $150 you can decide between a LGA1155 i3-2100, a LGA1156 i3-560 or a AM3 Phenom II X4 965 all with a stockcooler as your budget is running out allready.
    A second HDD would be nice aswell to seperate OS/software and storage, but that's aswell beyond the budget.
    So. That pretty much sums it up actually. If the OP happens to find a deal on a boxed PC that matches the aforementioned hardware, but with either a lower price or a copy of Windows 7 ontop, well, then it's one of those situations, especially when the OP doesn't plan to do anything fancy with his PC within the next 2 or three years to come.
    AND! It's still not clear, if the OP has a retail-copy of Windows 7 and a screen allready at hand.
  18. Lord-Vale3
    Lord-Vale3 His Tremendousness
    1 Dec 2009
    Um, $350 - $100 does not equal $150
    Self-built is ALWAYS better, and is even worth a slight premium, because it lasts longer and chances are the warranty on your part most likely to fail is often still longer than the warranty on an entire OEM machine.
  19. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    +1 for self built, but its what you should expect as a general answer if you come here :D, best of luck if you do decide to build one yourself
  20. Ljs
    Ljs Modder
    4 Sep 2009
    This.
    Hold off for another two weeks and build a very good computer with a decent price tag.
