Cases Branded cases with psu??
Discussion in 'Hardware' started by blinkieleblind, 6 Feb 2012.
  1. blinkieleblind
    blinkieleblind Tings and such
    22 Feb 2010
  2. faugusztin
    11 Aug 2008
    Cases with different than ATX power supplies usually come bundled with a power supply. Considering it is Silverstone PSU it should be fine.
  3. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Does it have any details on the psu brand? I know some places try to do budget bundles and give you a decent case such as an antec 300 with no-name or low quality psus. I've seen tigerdirect do it a lot in store.
    I'm in Canada so I don't deal with scan, could you try e-mailing them asking for the psu details / brand information?
  4. faugusztin
    11 Aug 2008
  5. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    It's a Silverstone case and seeing as they sell their own brand PSU's it's probably one of them. Small form factors cases like the one you posted do not come with ATX PSU's and they are difficult for a non OEM to purchase.
    Silverstones information on that case.
    ninja'd!
  6. mansueto
    31 Aug 2007
    I'd trust a silverstone psu so if it has all the connections you need go for it.
  7. blinkieleblind
    22 Feb 2010
    thanks all ;)
  8. Deders
    Deders Modder
    14 Nov 2010
    The psu in the pic above looks different to the one in the case judging by the size, shape and sticker placement. Hopefully it is different as the one in the pic only has 8A on the 1st 12v rail.
    Most modern PSU's nowadays come with at least 18A on each 12v rail as they have to supply much more power via the motherboard to PCIe slots.
  9. faugusztin
    11 Aug 2008
    @Deders: it is not different. The picture is just a cutout with a label part of the PSU, so you can read it. Milo ML01 is not a modern case and the PSU is not modern either. And for a 300W PSU 8+14.5A@12V is good enough.
  10. blinkieleblind
    22 Feb 2010
    wont be using pcie anyway. just the on board sb gpu, nothing fancy for an office type pc.
  11. AoE
    AoE What's a Dremel?
    4 Oct 2011
    selling my sharkoon T9, brill case and cheap
  12. Deders
    Deders Modder
    14 Nov 2010
    Then hopefully the 2nd rail will power the CPU as 95W/12= nearly 8A. Either that or make sure it's a low power cpu, around 45W or there won't be any headroom for anything else, like Ram MB or drives.
