Cooling Brass elbow fittings?
Discussion in 'Hardware' started by -Xp-, 31 May 2005.
  1. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    Is it just me, or is it impossible to buy 1/2" elbow ("L") fittings in brass?
    Everywhere does them in plastic (as above), but I'm after them in brass to go with the rest of my system. I've searched high and low and can't seem to find these things anywhere. Has anyone seen them about?
  2. kbn
    kbn What's a Dremel?
    17 Mar 2004
    The only brass ones I can think of are for compression fittings. here
    Youmight prefer copper pipe elbows, much nicer/less restrictive (15mm ID/OD depending on type).
    There are two types:
    End feed - suppost to go over normal 15mm copper pipe,
    Street elbow - is 15mm copper pipe so it will go in other fittings (and your tubing would fit over it).
    You want the second type if you can find them, else you will need to solder a short bit of pipe in to use as your barb.
    You should have no problem getting 1/2" thickwall tubing over 15mm OD, maybe even thinwall but ive never tyed. They are cheaper aswell.. pack of 10 for ~£2.50 in focus,
    This page has them aswell, but you will need copper pipe for them (they dont have proper street elbows - and I dont know anywhere that does). They have min order of 20meters, so unless you think you wil use all that, goto focus and get a 2meter length for £2.50..
    http://www.screwfix.com/app/sfd/cat/cat.jsp?cId=100555&ts=52985
    Or you cpould use these, but you need hose clamps, http://www.screwfix.com/app/sfd/cat/pro.jsp?ts=53389&id=75147
    Still have bigger ID than the plastic ones, and less sharp bend.
  3. Risky
    Risky Modder
    10 Sep 2001
    You can always get 90deg pipefittings in whatever thread you're on and screw you barbs into them. There's a couple of good uk fittings supppliers in the links sticky. Airlines or thorite both have a big parts list.
  4. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    That's a pretty sweet idea. I've got a load of spare barbs so I'll see if I can try it out.
