Networks Broadband checkers and actual speeds
Discussion in 'Tech Support' started by adidan, 9 Jun 2026.
  1. adidan
    25 Mar 2009
    So here's the scenario at the house we're buying
    " Openreach says FTTC available
    * BT wholesale checker using the UPRN doesn't say it's a one in one out on in the cabinet but it's a max speed of about 10mbps :eeek:
    * ISPs (besides one) say they can offer that 10mbps or so
    However, I know for a fact they currently get a 'superfast' (lol) connection much better than what the wholesale checker and ISPs quotes.
    So whats the best course, just order a 10 or so quoted connection (would the faster speed be automaticaly there if that's what it really is)
    Or just contact the current isp just before we move?
    FWIW they didn't used to get mobile coverage either and the mobile coverage checker says it's abysmal but that has been improved relatively recently and the signal was good and strong when I was there.
    Just not sure that if you'd get the 60 or so speed that's available automatically if you buy a part fibre plan that offers a 10mbps connection because that's what the BT wholesale checker says.
    Cheers all.
  2. wyx087
    wyx087 Multimodder
    15 Aug 2007
    Which ISP is your seller currently using? Worth going direct?
    When my area/house was initially wired up to FTTP (community fibre, not BT wholesale), it didn't show up on ISP comparison websites for quite a while, not even after my initial contract ended.
    adidan likes this.
  3. Midlight
    Midlight Modder
    6 Jun 2011
    I would agree with the above. We had similar last time the in-laws moved. Superfast was available on the street, the fibre hardware was visible on poles and 1 of the neighbours was connected. Most suppliers were not offering the superfast, just the copper/ FTTC connection. For us it was Sky that offered the fibre but, if its possible to find out who the current occupiers are using then I would ask them directly.
    adidan likes this.
  4. adidan
    25 Mar 2009
    BT and they also only show 10 as being available so that's why it's a bit odd.
    Yeah probably just best to check with them directly nearer the time which will be a little while yet.
    Local rural fibre is in the nearby area and I'll be registering interest in hooking it up in the future.
    E: Thanks guys
  5. gamesaregood
    gamesaregood Modder
    8 Apr 2004
    That does sound odd, I assume no alt nets are offering fibre in the area?
    Could be worth considering dare I say it starlink?
    adidan likes this.
  6. adidan
    25 Mar 2009
    Yeah it is an odd one. Nearer the time I'll get some more details of the seller, nice chap. Probably will just need a call to BT as he's getting far better speeds than I can find online from them.
    It's just an odd spot, even for mobile the actual coverage checkers seem to indicate it's shocking and yet he says it's been upgraded relatively recently and it was better on my phone when I was looking around than where were currently living. :happy: Odd.
    Been looking at alts, not found any hooked up yet, will look a bit more been a bit busy with all the checks and initial gubbings this week. I do know yhe rural fibre lot have connected nearby areas and they're assessing the area we'll be moving to, which is good.
    If all else fails if the mobile signal is consistently good then that's an option but if the line is currently good enough hopefully I can sort that out until fibre is there.
    Don't think Elon needs any more money.
    Mr_Mistoffelees likes this.
  7. Mr_Mistoffelees
    26 Aug 2014
    Methinks we can be damn sure, he won't be using some of his money for philanthropy, unlike Bill Gates.
