Peripherals Broken laptop key replacement
Discussion in 'Hardware' started by noizdaemon666, 1 Oct 2010.
  1. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I have a laptop, an MSI CR610 to be precise which has had its right shift key removed and broken :(
    Just wondered if anyone knew if its possible to get a replacement and if so where to get one from?
  2. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Call the manufacturer. They'll likely tell you that they don't replace individual keys and that it isn't a user-replaceable part.
  3. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Ninja-steal one from another laptop. Whaaat? Its an idea heuheu
  4. GoodBytes
    20 Jan 2007
    You need to replace the keyboard. If the key fell, usually the holding mechanism is also broken. And no manufacture will send you just 1 key. They usually sell laptop keyboard (directly fro, the manufacture) at about 80-150$ U.S, depending o their quality and if it's a backlit keyboard or not.
  5. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    nip to your local pc shop, that does repairs, they may have a key that fits
