Broken Mobo / Ram Issues - DFI UT NF4 SLI-D
Discussion in 'Tech Support' started by AlexB, 8 Apr 2006.
  1. AlexB
    AlexB Web Nerd
    22 Dec 2005
    Hey everyone.. Got a bit of a problem with my Mobo at the moment.
    I flashed the bios and made a mess of things last night, see this thread for details:
    http://forums.bit-tech.net/showthread.php?t=110800
    And now my ram only works in the first two slots, and not the others. This means I can't run in Dual Channel mode.
    It was working fine before I started messing about with the Bios.
    Anyone got any ideas?
    I'm using 2gb (2x1) G.Skill HZ DDR400 ram.
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    What bios are you using?
  3. AlexB
    AlexB Web Nerd
    22 Dec 2005
    I just downloaded the latest from the DFI site.
  4. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    I had the same issue with my SLI-D that I bought in Nov last year but it killed the ram module that was in the slots too. You should try taking the CMOS battery out, clearing the CMOS jumper and leaving it like that for >4hrs then pop the battery back in flick the jumper and try to boot. Test the ram to see which module still works (perhaps you got luckier than me and they both do) the check the memory slots one at a time with a working module (it won't boot and will just beep if you're using one module and you put it in a slot which is broken). Once you've established that two of the slots have failed (most likely outcome) RMA it and DFI will refurb it for you. Good luck!
