Modding Broken Neon-String Inverter
Discussion in 'Modding' started by Hwulex, 13 Mar 2002.
  1. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
    Ok, the wires on this have never been that great, and when I went to plug it in last night, they both pulled clean out the bottom. I wouldn't normally mind, but it's a sealed unit, and can't get to the insides to fix it.
    Any ideas?
    And can a CC inverter be used instead?
    |H|
  2. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    I doubt a cc one would work, i would try hacking into it somehow, maybe slice thin layers off, one at a time with razor knife. If still no joy, you can buy 12v inverters for it. Look at the link on the thread about lighted fans, i know they have em, there are other places too.
  3. tigermain
    tigermain What's a Dremel?
    24 Mar 2001
    Mine (exactly the same) has just given up the ghost as well, Im gonna have a closers look but not sure what the course is yet !
    I have a spare on here, but its got a different connector on it :( Will get back to you once I've had a look
  4. tk421
    tk421 Idiot.
    15 Jan 2002
    ill bet thats just vacuum-formed plastic over 1/2 a tiny project box, id take an exacto to it very carefully, with lots of light and maybe even a magnifying glass, then once you get it open and re-soldered, you can get really big heatshrink at autoparts stores, fix it up good as new ..
  5. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    its a plastic container, with all sides apart from one.
    inverters in the bottom and the rest is filled with resin.
  6. Hwulex
    1 Feb 2002
    And the resin is a b1tch to try and get out. unsuccessful so far :(
