Windows BSOD Error codes
Discussion in 'Tech Support' started by Minitoz, 20 Aug 2013.
  1. Minitoz
    Minitoz What's a Dremel?
    29 Jun 2010
    Recently, every time I use my pc, I get about 30 mins of use before I get a BSOD. The details are as follows:
    Problem signature:
    Problem Event Name: BlueScreen
    OS Version: 6.1.7600.2.0.0.256.1
    Locale ID: 2057
    Additional information about the problem:
    BCCode: 50
    BCP1: FFFFF8000CB78210
    BCP2: 0000000000000001
    BCP3: FFFFF80002F6A1FF
    BCP4: 0000000000000002
    OS Version: 6_1_7600
    Service Pack: 0_0
    Product: 256_1
    Files that help describe the problem:
    C:\Windows\Minidump\082013-45692-01.dmp
    C:\Users\Andy\AppData\Local\Temp\WER-58687-0.sysdata.xml
    This has only just started in the last month or so since I moved house. At first, I was having temperature issues, my cpu was at 99 degrees on idle. Since then I have taken off the cooler, cleaned it and the CPU, reapplied thermal paste and put it all back together. Temps went down to around 30 degrees on idle. Since that problem was dealt with the BSOD has started.
    I have reformatted my C drive and reinstalled win7 Ultimate 64 several times now but I keep getting the same error code.
    My system specs are:
    CPU: INtel i5-750 @ 2.66Ghz
    Motherboard: Gigabyte H55M-UD2H
    RAM: Crucial Ballistix Sport 1600 MHz
    GPU: Sapphire Radeon HD5850
    PSU: Be Quiet 650W
    Cooler: Arctic Cooling Freezer 7 Pro.
    Any help with the above will be greatly appreciated as I am getting to the point now where I am considering just binning the pc and starting a fresh new build.
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Can you upload the dump file?
  3. Minitoz
    29 Jun 2010
    err ...... how do I do that?? :D
  4. saspro
    saspro IT monkey
    23 Apr 2009
    Stick it in dropbox and send me the link
    The file you want is C:\Windows\Minidump\082013-45692-01.dmp
  5. Minitoz
    29 Jun 2010
  6. saspro
    saspro IT monkey
    23 Apr 2009
    ntoskrnl.exe+6f880 PAGE_FAULT_IN_NONPAGED_AREA usually points at memory.
    Can you post up the log file as well please from C:\Users\Andy\AppData\Local\Temp\WER-58687-0.sysdata.xml
    Minitoz likes this.
  7. Minitoz
    29 Jun 2010
  8. saspro
    saspro IT monkey
    23 Apr 2009
    I'd run a memory test on both your system & your GPU.
    I'd say it's one of those two areas.
    After that a disk scan and potential repair install would be advised.
  9. Minitoz
    29 Jun 2010
    Thanks very much, I'll give it a try and let yo know whats happened.
  10. Minitoz
    29 Jun 2010
  11. Minitoz
    29 Jun 2010
    Ok, so I ran memory test and everything is fine. I then went to use MSI Afterburner and a pop up window tells me there is no display driver installed. Anyway, I ran dxdiag and my GPU isn't even detected. I'll try reseating it and reconnecting power leads.
    Incidentally, can anyone recommend a fairly decent GPU for around the £200 mark? I'm tempted to go for Nvidia as I have always used ATi and feel like a change. I'm not overly bothered about max frame rates for Crysis 3 or anything like that as I mainly play WoW or SWToR.
  12. narwen
    narwen narwen
    6 Aug 2010
  13. Minitoz
    29 Jun 2010
    Ok, after doing a full fresh install, everything went well until I installed my GPU drivers, as soon as they were installed, I got another blue screen. So I'm guessing that my GPU is screwed?
  14. saspro
    saspro IT monkey
    23 Apr 2009
    Either the GPU or it's a bad driver
  15. Minitoz
    29 Jun 2010
    I tried older drivers and get the same problems. Thanks very much for all the help. New GPU time. Good bye to the HD 5850, Hello Nvidia GTX 760
