Apple Btconnect email on ipad and nokia lumia
Discussion in 'Tech Support' started by atc95, 6 Jan 2013.
  1. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    Hi wondering if some of you could help.
    My parents got an ipad 3 and nokia lumia 820 for christmas and birthday respectively and neither are able to use their btconnect email successfully.
    ipad: Can reveive email but not send email, using a variety of settings from bt customer support it either says ...rejected name.lastname from server or ...rejected name.lastname from server as server does not support relaying.
    Lumia 820: can only get email via the internet rather than as a mail account (live tile) so you have to keep going online and typing in password which I am told is a nightmare.
    If you need any specific details let me know.
    Thanks!
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    Are they connected to the their bt broadband when it rejects sending? If not you may need to change the smtp server to mobile broadband providers.
  3. atc95
    3 Dec 2012
    Yes they are both on bt broadband and I have tried both pop smtp and outlook mail servers
  4. RichCreedy
    24 Apr 2009
    Have you tried setting the smtp port to 587
  5. atc95
    3 Dec 2012
    Yes, that is the default when you try and add the account.
  6. RichCreedy
    24 Apr 2009
    Ok, default is normally 25 so maybe try that
    If that doesn't work, put a tick in the ssl box
  7. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
  8. atc95
    3 Dec 2012
    already tried the first 3 on that search with no positive results :( it is not a urgent issue as they both have laptops but I (being the house tech support) always get complained to for their gadgets not working "properly".
  9. short1uk
    short1uk Minimodder
    20 Sep 2011
  10. Krikkit
    21 Jan 2003
    Have they been migrated to the new Office365-powered BT email system? The settings have completely changed from the old ones if they have.
    Have a look here: https://myoffice.bt.com/MigrationLogin.aspx, on the right hand side it has instructions for setting up on various devices.
