Bubbles in AIO
Discussion in 'Watercooling' started by WarrenJ, 14 Dec 2018.
  1. WarrenJ
    WarrenJ Well-Known Member
    14 Oct 2009
    I have a Corsair Hydro Series H115i PRO RGB installed into my system.
    It is currently installed vertically with the outlets of the radiator at the top.
    Every now and again, I can hear bubbles going around the loop and I just wanted to make sure this is normal or if this is something that I would need to address?
    Many thanks!
  2. CrapBag
    CrapBag Well-Known Member
    17 Jul 2008
    I have an aio in the itx pc we use as a portable to take to my in laws house and it makes a right racket for about 2 mins after the car journey but then goes pretty much silent.
    Do you have the option to mount the rad with outlets at the bottom as that would stop it doing it most likely.
  3. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    How do you even fit a chimpanzee in an aio?
    Sentinel-R1 likes this.
