Build Advice Budget build
Discussion in 'Hardware' started by grritsshawn, 20 Apr 2009.
  1. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    Okay well i wanna build a buget pc i already have a power supply hdd and case the only thing i need are
    Mobo
    Cpu(2.4ghz+ plz)
    Ram(4g+)
    gpu(don't know much a decent one that can run like call of duty on low settings
    I am gunna spend a max of 280 shipped
    This is what i was thinking about getting
    mobo-Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100 Ethernet LAN, USB 2.0, Serial ATA, RAID-
    Price 49.99 usd
    Cpu-AMD Athlon 64 X2 5000+ Processor ADO5000IAA5DO - 2.60GHz, 1MB Cache, 1000MHz (2000 MT/s) FSB, Dual-Core, Socket AM2, OEM Processor
    price 54.99 usd
    ram-Kingston PC6400 800MHz 4GB DDR2 Desktop Memory - 4096MB, 240 Pin
    price 49.99 usd
    Gpu-Visiontek Radeon HD 3650 OC Video Card - 1GB GDDR2, PCI Express 2.0, CrossFireX Ready, (Dual Link) Dual DVI, HDTV, HDMI Support
    price 49.99 usd
    other-Ultra X-Wind CPU Fan Aluminum Socket 775 with PWM Control
    price 19.99 usd
    total 219.95 usd
    not sure if thats good or not
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I'd say get an E5200 instead, will be a lot faster (especially after overclocking).
  3. Singularity
    Singularity ******* Operator from Hell
    2 Mar 2008
    I really wouldn't go with that card... In general, avoid low end cards with 1GB of memory, that's just a huge waste... You're much better off with a 4670 with 512MB of memory (doesn't really matter what brand, just try and not get a Gigabyte since they're awfully loud).
    Also, is that ram a single stick? The price seems awfully high. Go with a pair of 2 GB modules instead, you should be able to get a pair of corsair 2GB modules for less money.
    As far as the CPU and mobo go, I'll let someone else be the judge, I know very little about low end AMDs...
  4. trig
    trig god's little mistake
    10 Aug 2006
    that budget is pushing it my friend. going to have a hard time finding good, quality components at that price point for those items.need another $30 to $50 to make it worth the upgrade. In addition, you understand OEM cpu means no heatsink/fan.
  5. grritsshawn
    20 Apr 2009
    Well i wont be doing high end gamming proble games like runescape on high detail which you dont need a really high end card for it
  6. Guest-16
    Guest-16 Guest
  7. grritsshawn
    20 Apr 2009
    ya thats why i'm proble gunna get a fan for it
  8. grritsshawn
    20 Apr 2009
    Well i'm not familair with over clocking i have somewhat of an idea i play games like runescape(mmropg) check it out good game and i would like to play guild wars but cant
    My buget is about 250-275 max I rather not have to spend that much.I found a set up that i was guess was good guess i was about 40 bucks cheap of a good set up
  9. grritsshawn
    20 Apr 2009
    Here is the new set up
    Mobo-MSI G31M3-L V2 Motherboard - Intel G31, Scket 775, MicroATX, Audio, Video, PCI Express, 10/100 LAN, USB 2.0, Serial ATA
    cpu-Intel Pentium Dual Core E5200 Processor BX80571E5200 - 2.50GHz, 2MB Cache, 800MHz FSB, Wolfdale, Dual Core, Retail, Socket 775, Processor with Fan
    ram-Kingston PC6400 800MHz 4GB DDR2 Desktop Memory - 4096MB, 240 Pin(these are 2 sticks of 2048 each)
    gpu-Sapphire Radeon HD 4650 Video Card - 512MB DDR2, PCI Express 2.0, CrossFireX, Dual-Link DVI, VGA,
  10. trig
    10 Aug 2006
    if that hits the budget, sounds like a winner. the board is a little meh...but at least it is cheap so if you need to replace soon you won't be out all that much. you definitely wont be getting much of an oc goin on it. If you have the ability(about $20), I think a Gigabyte GA-P31-ES3G would be a better choice if your case can handle ATX.
  11. grritsshawn
    20 Apr 2009
    Proble gunna be put on hold till july cuz of money issues
