Cooling Budget full watercooling kit.
Discussion in 'Hardware' started by AnarKy, 28 Jun 2004.
  1. AnarKy
    AnarKy What's a Dremel?
    6 Jun 2004
  2. Bloodsmoke
    Bloodsmoke What's a Dremel?
    20 Jan 2004
    I would have to say the Aquarious. It pumps more water(not always a good thing)but it comes with a resivour, as with the other one you would have to buy it separatly.
    Also, i would recomend getting a graphics card waterblock, if you have a system, might as well cool more than 1 thing.
  3. Darv
    Darv Bling!!
    12 Aug 2002
  4. eUphoria
    eUphoria What's a Dremel?
    9 Apr 2004
    i'd tend to agree with darv, havent used the tt aquarius to be fair, but although not a fantastic kit the asetek isnt too bad and at the price i reckon its the better buy!
  5. eUphoria
    9 Apr 2004
    or of course, if you're feeling a bit more ingenius you could probably keep an eye out on the forum trading posts and build a custom design watercooling rig that will (probably) cool a bit better and (if you're lucky) wont cost too much if anything more!! Depends how confident you're feeling - i'd build my own from scratch (and did!), cools my xp3200 to 36/37 idle and 40 full load.
  6. Darv
    Darv Bling!!
    12 Aug 2002
    Yup building your own kit out of your specified parts is the best way to do it but it's not something you can do on a whimsy. You need to read a lot about the subject. (Hose sizes and thread sizes still confuse me :duh: ) Then you need to carefully think about what components you want.
    The Asetek kit will get you started and comes with everything you need. Then after that you can start delving into more custom parts.
  7. toss
    toss What's a Dremel?
    6 Jun 2004
    Iv made my own watercooling kit parts arriving soon and it cost me 250nzd
    so about 125 usd :p plus things are cheaper in the us and britain so really its not that expensive to design you own kit
  8. Firehed
    15 Feb 2004
    The asetek without question. It comes from a brand with good cooling components and includes good parts. By entry level they must just mean 1 block because it's actually a decent setup.
    I have an aquarius... it's mediocre at best. It can easily be beaten by a good air heatsink.
  9. Risky
    Risky Modder
    10 Sep 2001
    I have used both and there is no comparision. The TT kit is a very basic cooling loop that may be handy is some applications but will not perform anything liek waterchill. Additionally Waterchill is compatible with other systems using similar fittings and can be expanded, modified and upgraded as required.
    I'm amazed at the price of that kit these days, it's definitely a great entry point.
  10. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Asetek WaterChill kits are pretty dam good for a kit. You wont be dissipointed :D
  11. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    urm, im quite interested in that waterchill kit, but how on earth do you fill it, or let air out, without a res?, the ones they supply with their full kits look pretty basic, i cant believe they aint included it..
    so.. filling, on that waterchill kit, how?
  12. pumpman
    pumpman Minimodder
    7 Jul 2004
    komplett are doing the asetek for 110 quid now i paid 150 notes six months ago
    you fill it through the reservoir that is attatched to the pump
  13. thorilan
    thorilan What's a Dremel?
    25 Aug 2003
    standard water cooling and water chilling is very diferent
    to fill and bleed them you can use a T in the hosing and cap it off with a long peice of hose and a plug
  14. robthebob
    robthebob What's a Dremel?
    31 Jul 2003
    I've had the KT12 kit for a while now, and I've been very satisfied with it except for one thing - the pump makes a lot of noise. It's something of a buzzing which is needless to say very irritating particularly seeing as water is supposed to be quiet. I guess it's probably air trapped in the system, but running it for ages doesn't seem to help and the entire system has been flushed 3 or 4 times now. Is the hydor L20 just a cheap pump and I should get a new one, or am I doing something wrong?
  15. Michael10642
    Michael10642 What's a Dremel?
    3 Mar 2004
    You're probably doing something wrong, as I've had the L20 pump and it's hardly noticeable in use.
    Are you sure it's not making contact with the case directly and causing the whole thing to vibrate and cause a hum? Other than that is to check the water, if it's nice and clear, then you don't have a problem with air. If it's like a frothy white, then you have air in the system, might be able to fix that by turning off everything for a few hours and let it settle.
    If all that fails, then you might have something that isn't sealed properly and that's letting some air in that is causing a noise @.@
  16. robthebob
    31 Jul 2003
    The water looks fine - no froth at all. The buzzing is definitely not coming from case vibration either as I tried lifting the pump away from the case and the noise didn't change. It sounds like air could be trapped in the pump, but I've no idea how to get it out.
  17. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    hi there
    have you tried spme watter wetter? found this made such a difference to my l20. i put a few drops into the first resovior load of water when i fill it.
    so what temps are you getting
    i am getting 41c full load on a 2500xp-m @ 1.75v
    not bad i think
  18. Goldfish
    Goldfish What's a Dremel?
    4 Jul 2004
    What on earth is spme watter wetter? Some sort of chemical to reduce surface tension perhaps?
  19. slaw
    13 Feb 2003
    what do you think spme is?? could it be some misspelled?? don't know it will take me a week to work that one out
  20. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    i've imported my stuff form the US dnagerden site, u can get soem great deals over theres. especially with the current exchange rate.
