Budget graphics, and faster processor
Discussion in 'Hardware' started by M3G4, 29 Jun 2002.
  1. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    I've been surfing GTA3Forums.com... there's been alot of problems with it :(, But, I've checked the system requirements and my system meets every one EXCEPT the graphics card (see my sig for system details). GTA3 requires a graphics card with at least 16MB on-board RAM. Any ideas what I could get? I don't want to spend an awful lot as this machine is getting OLD now...
    Also, I have a ATC6240 motherboard, "The ATC6240 supports all Intel Pentium II/III/Celeron processors. It features 4 DIMM slots supporting a max of 1GB SDRAM, and a CPU Ratio selection of 3.5x ~ 6.5x.". The manual claims it has a 133MHz BUS, But apparently this motherboard can't accept coppermine chips... what can I do to speed this thing up?
  2. Cruelinios
    Cruelinios EvE Addict
    21 Jan 2002
    check if the motherboard is AGP 2.0. If it is, then get yourself a Gainward GeForce2 MX400 64MB for £29.99 at http://www.komplett.co.uk.
    If it isnt AGP 2.0, then get a PCI graphics card.
    To check if it is 2.0, go to your mobo companies website, and check there.
  3. Lazy
    Lazy Meow?
    13 Nov 2001
    GTA3 is one of the most demanding games i have ever run. I have to run it at 1024 x 768 so it runs smoothly. Specs in sig.
  4. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    To be honest, As long as runs at 12fps or more at 640x480, I'm not bothered. I'm not fussy about the res, and to be honest, 1024x768 is not really a preferable resolution..
    Also, I've heard bad comments about the MX cards.. would it do justice in games like Q3A, UT and Midtown Madness 2?
  5. Cruelinios
    21 Jan 2002
    well for the price its will do its best, it does well tbh. If you want something a bit faster, you will have to go to £70 or more :( but the MX is a very nice card, I have run it with many games, a lot faster than your stone age intel gfx board mate :D
  6. Lazy
    Lazy Meow?
    13 Nov 2001
    mx cards are not very good for perforance systems but it might be the best you can get.
  7. RTT
    RTT #parp
    12 Mar 2001
    :eeek: :eeek: :eeek:
    12!!
    You'd want 25 minimum cos that what TVs run at?
  8. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    Nah, MM2 ran at 12fps with this i740, and I could cope with that. I would like framerates of 25+ tho, but that's asking for a miracle with this type of system.
    Hmm, I'll try the MX. I just need something to keep this machine going for a while, since my i740 has decided it doesn't support 3D graphics anymore
  9. herbs
    herbs Nobody but us chickens
    7 May 2001
    Get a cheap ati 7500 for about £60 or a gf2 ti for about £70 and that will play ok @ lower res for you.
  10. Cyberdome
    Cyberdome What's a Dremel?
    4 Jan 2002
    im running a MSI GF4Ti4200 64MB on a Duron 700MHz .. and it doesn't lag ... realy suprise me though .. coz i thought that the Duron will be bottlenecking it ... but didn't ... (not really)
    running 800x600x32 without any problems
  11. Adam
    Adam Minimodder
    26 Jan 2002
    The MX Geforce 2 I had was quite quick, but for GTA3 make sure you get the 64mb version fpor GTA3. Also invest in some more ram, you can pick up another 128mb for £15 atm, and it will make a big difference to the game.
  12. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    Cruelinios - Komplett don't sell them for £29.99... They were quite expensive, Although I did find an Inno3D GF2MX400 64MB for £40 on dabs. What should I buy? I don't really want to pay more than £40
    Adam - Where can I get 128MB more RAM for £15?
    I wonder if my motherboard can handle a faster processor :idea: probably not knowing my luck :(
  13. Adam
    Adam Minimodder
    26 Jan 2002
    Get the £40 one on dabs. You can get 128mb for £15 on komplett I think, www.cclcomputers.co.uk sell it for around that price. Another site I buy from quite often is www.xcase.co.uk, they offer bulk discounts and good prices.
