Cases Budget mini-tower recommendations (rosewill, coolermaster, silverstone in thread)
Discussion in 'Hardware' started by simon_C, 17 Dec 2012.
  1. simon_C
    simon_C Minimodder
    13 Nov 2005
    My old case recently got damaged in shipping and I'm looking for a nice ultra-short mini tower case for my desktop, for under 50$. It doesnt need to be anything special.
    I was looking at the Cooler master Elite 341, which seems nice because it has 4 120mm fans and is nice.
    I was also considering the Rosewill Line-M, which seems to be about the same as the above.
    Then i found the Silverstone Tek PS08B, which is nice looking and it has a good brand attached to it.
    Id like to keep it under 50$ because money is tight. Are they any others that can be recommended? any secrets or otherwise good budget mini towers?
  2. Booti
    Booti Minimodder
    17 Jan 2011
    I can't find a cooler master 341 listed on their website, so can't really say anything other than I note it doesn't appear to have USB3 on the front.
    The Rosewill does have the USB3 but appears to be limited to just 2 internal hard drives.
    The silverstone has more hard drive space and the USB3, but less cooling (smaller fans at th rear and none side mounted)
  3. simonw
    simonw What's a Dremel?
    24 Jun 2009
    The COOLER MASTER Elite 361 is a compact case for about $40. I don't particular like the case but it's another option for you.
  4. simon_C
    simon_C Minimodder
    13 Nov 2005
    Not a huge fan of the cooling situation on the 361.
  5. simon_C
    simon_C Minimodder
    13 Nov 2005
    I'm really leaning towards that rosewill case because i cannot find one of the cooler masters for sale, i already had one go on backorder after i tried to buy it.
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Fractal Design Core 1000?
    Antec 300?
    I have one PC in a Core 1000, and while the build quality is what the price suggests, it's pretty decent. Installing a full width Micro-ATX motherboard was a bit tricky. The front fan is said to be loud, but I've never plugged it in. The Antec 300 is very good, but it might be a bit expensive.
  7. simon_C
    simon_C Minimodder
    13 Nov 2005
    Well i guess i'm gonna go with that rosewill.
