HTPC Budget Projector
Discussion in 'Hardware' started by lcdguy, 27 Nov 2005.
  1. lcdguy
    lcdguy Minimodder
    25 May 2004
    I am looking at getting a projector and have come down to 2 choices (the only ones in my budget)
    Benq MP610
    or
    Epson S3 (i can get it from costco and it comes with a free screen :).
    I am leaning towards the epson as the bulbs are relatively cheap.
    Let mw know what you think.
  2. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    I've heard that Benq projectors are pretty good. I've not heard much about Epson projectors. Also take a look at the Infocus X2, which should be in your budget, and which I've heard good things about.
  3. lcdguy
    lcdguy Minimodder
    25 May 2004
    how expensive are the lamps in the infocus units also is the infocus a DLP or LCD prjector as i am afriad of going with DLP for fear of being affected by the "Rainbow Effect"
  4. ridiculous
    ridiculous What's a Dremel?
    21 Jan 2005
    my infocus lp750 bulb cost me $400 to replace the bulb
  5. lcdguy
    lcdguy Minimodder
    25 May 2004
    see thats why i am leaning towards the epson as the bulbs are abot 1/2 of that fro a 2000h standard / 3000h econo. Also i saw the Epson S10 in store today and i really like the image quality so i think i am going ot get the epson S3 as the S10 is out of my budget.
  6. mushky
    mushky gimme snails
    24 Mar 2003
    You might get the rainbow effect with a DLP, or you could get screen door effect with an LCD. Which one of these is better for you needs to be judged by you. Is there any way you can test them out first?
    Both are 4:3 ratio, are you OK with that?
    2000 hours is a lot of hours mate. thats about 1 film per day, every day for 3 years! It is more likely that you will want to upgrade your projector before the bulb runs out.
    I hear good things about the Infocus ones as well. You should check them out at least.
  7. FuzzyOne
    FuzzyOne
    19 Sep 2002
    +1 for InFocus products
  8. lcdguy
    lcdguy Minimodder
    25 May 2004
    the problem with infocus is that i am on a tight budget andall of the place i have seen that are selling them even the X1's are over my budget by about 300 bucks. and yes i am fine with it being 4:3. my other problem is that i can't buy anything online thats more thean $1000 bucks since i am still a student and my credit card comapny wont increase the limit. :( So maybe i should wait on this ?
    ok clarify things this is budget total including taxe, shipping, etc.
    $1000CDN = $857.64 USD = 498.175 GBP
    so you can see i am on quite a tight budget.
    UPDATE
    if i were spend a little extra do you think these would be worth it.
    Benq PE5120
    or
    Hitachi PJ-TX10
    if i needed to i could increase my budget a little, but i would have to use my paretns credit cvard to purchase this.
  9. wharrad
    wharrad What's a Dremel?
    26 Jul 2003
    Currently using a Benq for my tele in the living room and I'm impressed with it. Nice picture and all that - not too loud (but could be better).
    Saying all that, I would recommend it, but I have no other experience.
  10. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Tight budget? how bout this
  11. mushky
    mushky gimme snails
    24 Mar 2003
    For that budget you could get a really nice high def projector 2nd hand. A nice Sanyo or Panasonic or something. That's what I would do, but I would be very selective of who to buy it from.
