Peripherals Budget racing wheel
Discussion in 'Hardware' started by isaac12345, 13 Jun 2010.
  1. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Hi,
    I want to buy a racing wheel for the upcoming Codemasters F1 2010 game. I've tried the Logitech G25 and its awesome. Unfortunately, I dont have the money to spend on it. Are there any good and cheaper alternatives, preferably closer to the £50 mark?
  2. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    Bumping this as i have a similar problemusing a joystick hurts my arm after a shortwhile and i can't get a gamepad that is sensitive enough.
  3. isaac12345
    20 Jul 2008
  4. Coltch
    Coltch Minimodder
    3 Jul 2009
    It might be worth seeing if you can get a MOMO from ebay.
    I'm using an old Logitech Formula Force which, although not brilliant, does OK.
  5. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    before i got my G25 i had a logitech drive FX, its an Xbox 360 wheel but worked fine in windows. Its not the greatest wheel but its better than a control pad and can be found for around £35 online.
  6. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    I have heard good things about MOMO, so that might be an option, allthough I really don't know about it's pricing.
    I recently got myself G27 for my first wheel, and I'm loving it to bits. Sure it ain't actually cheap, but I knew I would have upgraded sooner or later anyways, so I it actually saved me some cash :)
  7. KD88
    KD88 Minimodder
    25 Aug 2009
    Issue 76 of Custom PC did a Labs Test on four budget wheels and the Saitek R660GT came out well with an Approved score of 83% and a retail price of less than £50.
    Just done a shopping search on Google and there appears to be a bit of a shortage, but it is still listed on Saitek's web site so you could e-mail them for more information.
    The Logitech Driving Force GT Steering Wheel seems to get good reviews but is a little more expensive at £90 from Play and Amazon allthough there is one on e-bay if your quick.
  8. Sexton
    Sexton Minimodder
    2 Jun 2010
    With steering wheels it really is a case of 'get what you pay for'. My only advice is do not even consider something that isn't Logitech. I am using a Logitech Driving Force GT, which although is PS3 wheel, does work fine on PC. Bought mine for around £70 a year ago so probably cheaper than that now. Other than that there is the G25, and tbh they are the only two worth even looking at.
  9. isaac12345
    20 Jul 2008
    oh! I didnt know CPC did a lab test for them. Is it possible to access previous issues online? I'm a subscriber.
