Build Advice Build Advice - 1200
Discussion in 'Hardware' started by benedictnz, 7 Jun 2010.
  1. benedictnz
    benedictnz What's a Dremel?
    7 Jun 2010
    Budget: <=1500
    Main uses of intended build: Gaming (FPS/RTS), some TV/DVDs.
    Parts required: All
    Previous build information (list details of parts): None
    Monitor resolution: 1920*1080
    Storage requirements: Just OS + some games (I have an external HDD for data)
    Will you be overclocking: yes
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): SLI. Future proofed a little.
    Extra information about desired system:
    • Minimalist looking case (Fractal Design R2/ Antec 300?). Quiet, dust free and cool.
    • While the budget is relaxed, I'd prefer to spend less.
    • Will put a second GF in SLI in the future. Prefer GF as I like PhysX and CUDA even though heat +power from GF is high. But prepared to be swayed to Ati.
    • I also would prefer to buy all components from one place and have them assemble and test (I dont want to have to play the "find out which components are dud" game).
    • Monitor suitable for gaming and watching TV/DVDs on. Approx 24" preferred. My last was a 40" LCD TV so all sizes around this range will be similar to me. Must be 1920*1080 or better.
    My thoughts so far:
    component name web price incl. VAT
    • case - antec 902 - £ 75.00
    • psu - coolermaster 850 silent pro - £ 96.00
    • mobo - asus p7p55d-e pro - £ 170.16
    • cpu - core i7 860 - £ 195.00
    • cooler - noctua nh-u12p se2 - £ 39.00
    • ram - GSkill F3-12800CL7D-4GBRM - £ 93.94
    • ssd - ocz 60gb vertex - £ 120.42
    • cdrom - lg 22x - £ 13.00
    • gpu - zotac geforce 470 - £ 275.00
    SYSTEM TOTAL £ 1,077.52
    What should be changed? I see the buyers guide has everything different apart from the CPU...
    eg: Should I get an intel 750, 860, 875k, 920, 930, etc? Should I air cool or water cool? Should I OC to 4GHz, or try for 4.5GHz? Etc.
    What monitor should I get? I'm thinking HannsG HH251HP based on this buyers guide. Want to keep the budget down...
    Should I buy from a place in London since I live there (eg: http://www.yoyotech.co.uk), or does it not matter much? (I've just moved to the UK from NZ so not sure about things like that).
    Cheers, Ben.
  2. benedictnz
    7 Jun 2010
    cheaper build from aria - £1100 incl VAT
    • 43.46 - Antec Three Hundred Gaming Midi Tower Case - Black
    • 229.11 - Intel Core i7 860 2.80Ghz (Socket LGA1156) Processor - Retail
    • 35.24 - Titan TTC-NK85TZ Fenrir V2 (Socket 939/AM2/LGA775/LGA1156/LGA1366) CPU Cooler
    • 299.61 - Zotac GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card
    • 140.99 - OCZ 60GB Vertex Series SATA-II Solid State SSD 2.5" Drive
    • 93.99 - G.Skill Trident 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit
    • 108.09 - Corsair TX Series 850W ATX2.2 SLI/Crossfire Compliant Power Supply
    • 135.11 - Asus P7P55D Pro Intel P55 (Socket 1156) DDR3 PCI-Express Motherboard
    • 14.68 - Samsung SH-S223C 22x Internal DVD±R/RW SATA Drive - Black
    • I think this is the cheapest motherboard that does SLI. (I do want to put a second 470 on later).
    • I think the Antec 300 case is good enough for cooling based on the review of the Utgard.
    • The Titan Fenrir also seems to be a totally sufficient cooler.
    • Opinions?
  3. StudioRecorder
    StudioRecorder Mobo's need Fabo's for company!!!!!
    14 Jan 2010
    for that price i would spec a similar machine to the one i just recently built:
    case: Antec 300 - £37.48
    Memory: 6GB (3x2GB) Corsair XMS3 1600MHz DDR3- £142.32
    Motherboard: Asus P6T SE - £151.77
    CPU: Intel Core i7 920 - £179.97
    CPU Cooler: Titan Fenrir V2 - £29.95
    PSU: Antec Truepower 750W modular - £92.53
    HDD: 1TB Samsung F3 - £54.03
    GPU: Asus 5850 1GB - £223.23
    ODD:Samsung SH-S223C/BEBE - £14.97
    total: £1039.03
    dont know much about monitors to advise you on one (maybe someone else can) but the 5850 will easily be able to handle a monitor of 1920 x 1080.
  4. benedictnz
    7 Jun 2010
    whoops, double post! :(
  5. benedictnz
    7 Jun 2010
    Thanks StudioRecorder,
    Is it worthwhile going to a 920 over an 860? what are the practical differences once overclocked? Where did you buy your components? Did they assemble?
  6. benedictnz
    7 Jun 2010
    coere i7 1366 build for 1100
    • 180.94 - Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) Processor - Retail
    • 132.76 - Gigabyte GA-EX58-UD3R Intel X58 (Socket 1366) DDR3 PCI-Express Motherboard
    • 140.99 - OCZ Gold 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz Triple Channel Kit
    The 930 can overclock a little more than the 920, is that worth another GBP50?
  7. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Go for the i7 920 or 930, you will get 4GHz on air.
    Then go for a Gigabyte GA-X58A-UD3R, it is cheaper than the m/b you have spec'd.
    The Titan Fenrir is a much better cooler than the Noctua.
    £275 for a Zotac 470 looks cheap, the cheapest I can find on a reputable site is £289.99 at www.overclock.co.uk.
    Regarding where to buy from, I have purchased from the following online traders over the years:
    www.scan.co.uk (free delivery if you have posted 20 time in this forum)
    www.cclonline.com (another free delivery option for regular posters to this forum)
    www.ebuyer.com (they offer free delivery as well)
    www.aria.co.uk
    www.overclockers.co.uk
    www.dabs.com
    www.quietpc.co.uk
    My current preferences are for Scan and Ebuyer due to the free delivery and good prices.
  8. Fingers66
    30 Apr 2010
  9. Fingers66
    30 Apr 2010
    Almost all of us on these forums assemble ourselves, it is sometimes the best part about it...:D
  10. benedictnz
    7 Jun 2010
    Yeah, I normally assemble, but if any components are dud it'll be a real hassle to figure out whats gone wrong. I figure its much less hassle to buy all components from one place and get them to assemble. Less fun as well, but thats a trade I'm willing to make.
    Thanks for the list of websites, will price up a system in each.
  11. Fingers66
    30 Apr 2010
    You won't get an entire system from Quiet PC, only bits and pieces. It was more for reference.
    One more thing... a 470 (or two) are going to run hot. Choose your case carefully.
  12. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I've found Aria is the place to go, its so much cheaper than every where else :)
  13. benedictnz
    7 Jun 2010
    I think the Antec 300 seems pretty good (GBP~38), it performs the same cooling as the Cooler Master ATCS 840 (GBP~165) in this review. Based on that I dont know why I wouldnt buy it...
  14. Fingers66
    30 Apr 2010
    Cool, I hadn't spotted the Antec 300 lurking in the charts.
    Will it fit the 470?
    Quote from Antec website...
    "Maximum video card size: 11"/279mm (Note: some video cards may block access to the adjacent hard drive bay)"
    Maybe someone who has both can post a comment?
  15. benedictnz
    7 Jun 2010
    http://www.viritech.com/zotac-geforce-gtx-480-desaign-uber-graphics.html
    length of 268 mm
    http://www.zotacusa.com/zotac-geforce-gtx-470-1280mb-320-bit-607mhz-3348mhz-zt-40201-10p.html
    width - 241.3mm
    guessing the manufacturer is right, but even with the other "measurement" it'll still clear. But would also be good to hear from someone with both just to make sure.
    I also dont know if the cooler will fit in the case.
  16. oatey4519
    oatey4519 can't be arsed...
    5 May 2009
    I'd look at this setup as well
    Get rid of the 5850 and put in a GTX470 instead (got 2 of these)
    Not sure on the case - other can give advice there
    Always look at the Scan Today's Deal's as well - they always have very good deals to save a few quid.
    MB+Ram etc
    :idea:
  17. oatey4519
    5 May 2009
    How about this on Scan Today then?
    Seems very cheap
    Intel Corei7 920 Combo
    Xclio A380Colour, Tower Black+Window & 25cm Front & 25cm Side 256colour LED Cooling Fans w/o PSU
    800W EZCool Infinity PSU Dual/Quad Core SLI SATA 24V Dual 12v Intel v.2.2 120mm Fan
    Intel Corei7 920 D0 SLBEJ Bloomfield 45nm, 2.66 GHz, QPI 4.8GT/s, 8MB Cache, 20x Ratio, 130W, Retail
    Gigabyte GA-X58A-UD3R, Intel X58, S1366, SLi/Xfire PCI-E 2.0, DDR3 2200/1333, SATA 6Gb/s, RAID, ATX
    1TB Samsung HD103SJ Spinpoint F3, SATA 3Gb/s, 7200rpm, 32MB Cache, 8.9 ms, NCQ, OEM
    6GB (3x2GB) Corsair XMS3, DDR3 PC3-12800 (1600) Non-ECC Unbuffered, CAS 9-9-9-24, 1.65V
    Samsung SH-S223C/BEBE 22x DVD±R, 12x DVD±R, DVD+RW x8/-RW x6, SATA, Black, OEM
    http://www.scan.co.uk/todayonly/#1
    A lot less than your 1k
  18. Fingers66
    30 Apr 2010
    Check out Scan's today Only page...http://www.scan.co.uk/TodayOnly/Index.aspx
    - Intel Corei7 920 D0 SLBEJ Bloomfield 45nm, 2.66 GHz, QPI 4.8GT/s, 8MB Cache, 20x Ratio, 130W, Retail
    - 6GB (3x2GB) Corsair XMS3, DDR3 PC3-12800 (1600) Non-ECC Unbuffered, CAS 9-9-9-24, 1.65V
    - Gigabyte GA-X58A-UD3R, Intel X58, S1366, SLi/Xfire PCI-E 2.0, DDR3 2200/1333, SATA 6Gb/s, RAID, ATX
    £446.49 for the lot
    1280MB ScanFX GTX 470, 40nm, 3348MHz GDDR5, GPU 607MHz, Shader 1215MHz, 448 Cores, 2x DVI, mini HDMI
    £262.01
    Plus other stuff you may find interesting...
  19. benedictnz
    7 Jun 2010
    current build thoughts
    https://www.aria.co.uk/WishList/YNV73GRHT6Vlnln8MLWdYw,,
    Antec Three Hundred Gaming Midi Tower Case - Black £ 43.46
    Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel Kit £ 148.04
    Corsair TX Series 850W ATX2.2 SLI/Crossfire Compliant Power Supply £ 108.09
    Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) Processor - Retail £ 180.94
    Hanns-G 25" Full HD Widecreen Monitor with 2x HDMI £ 176.24
    Samsung SH-S223C 22x Internal DVD±R/RW SATA Drive - Black £ 14.68
    Intel X25-M Gen2 Mainstream 80GB 2.5" SATA-II Solid State Hard Drive - Retail £ 178.59
    ThermalRight MUX-120 CPU Cooler (Socket AM2/1156/1366) - Retail £ 44.64
    Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 PCI-Express Motherboard £ 164.49
    Zotac GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card £ 299.61
    Microsoft Wireless Optical Desktop 700 Keyboard and Mouse Set - Black (M7A-00027) £ 23.49
    Aria will build and overclock for me for a very reasonable price.
    Aria also recommended:
    1. thermalright mux-120 over the titan fenrir v2
    2. "Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz" over the "OCZ Gold 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz"
    Thoughts?
    Also thought I'd get the Hanns-G HH251H on the basis of this review: http://www.digitalversus.com/article-357-6883-322.html. Anyone used one?
  20. oatey4519
    5 May 2009
    Spooky.. great minds...:naughty:
