HTPC Build advice.
Discussion in 'Hardware' started by ac4155, 9 Jun 2010.
  1. ac4155
    ac4155 What's a Dremel?
    27 Dec 2009
    Hey guys,
    So, i plan on building my self a HTPC type computer. The plan is to have it be able to play blu-rays and DVD's, be able to browse the web, youtube, spotify, itunes, iplayer. things like that.
    I have got a few parts that i think i will use, but still want to run it by all of you before jumping into the deep end.
    so here they are:
    Motherboard: http://www.ebuyer.com/product/220410
    CPU: http://www.ebuyer.com/product/185937/show_product_reviews
    Hard drive: http://www.ebuyer.com/product/158798
    Optical drive: http://www.ebuyer.com/product/172638
    Ram: http://www.ebuyer.com/product/169489 (x2)
    Case: http://www.xcase.co.uk/X-Case-ITX-Atomic-Cube-p/case-x-case-atomic-cube-red.htm
    I would like it to be cheapish, and this current set up is about the price i would like it at, (tho cheaper would be good)
    I plan on getting a TV tuner for it as well so that i will be able to watch and record HD freeview, however i'm going to wait untill the DVB-T2 cards come onto the market. (which is the reason why the expansion slot is free).
    It would be nice to get the hard drive set up in raid but as i understand the motherboard does not support it, plus the case has no room for one (tho i could try and mod it to fit it in). I think one way to get around this would be an exturnal drive which is cloning the hard drive but i don';t no much about this really.
    so, any ideas of how i can improve this would be great. its basically going to be my 'tv' hub for everything rather than getting an apple one which is limited.
    Thank you for the help, and have at it :)
    AC
  2. Guinevere
    Guinevere Mega Mom
    8 May 2010
    You'll need an OS, and some bluray player software, but other than that the HW list looks good.
    Have you read a review of that case? How loud is that 8cm fan? And is there another in the PSU? Coupled with stock cooler, the HD and a spinning BR in the drive, it could turn out to be a loud(ish) HTPC.
    Also have you got a network cable to reach the HTPC where you want it? A lot of people have problem using iPlayer in HD over wi-fi. Your milage may vary.
    As to the Raid. Are you thinking to deal with a suddenly failing HD? If so then an external HD and a proper backup solution would be better than a pure "raid 1" type mirror. A basic raid will cope with the HD failing, but if something breaks the OS, you'll have two broken copies.
  3. ac4155
    27 Dec 2009
    ah, sorry forgot to add the os on which is: windows 7 home premium http://www.ebuyer.com/product/173787
    as for blu-ray software, is there any recommendations to which would be best?
    The only review for the case i have been able to find is the one which is a video on the product page, do i don't really have an idea about the noise levels of it. would there be a way to try and make it quieter? or possibly another case which would be low noise but still style (e.g. cubeish)
    Don't worry about the network cable, that is all sorted and will reach where it should be going.
    as for the raid, it is the failing HD that i'm concerned about. plus my laptop had an error with the os and i almost lost some files, so this is what i would like to have a back up for. what would you recommend for this setup?
    Thanks for the help :)
    AC
  4. ac4155
    27 Dec 2009
  5. ac4155
    27 Dec 2009
    anyone?
  6. ac4155
    27 Dec 2009
    Another question i have is what would be the best quietest 80mm fan that i can use in the case?
    thanks
    AC
  7. mrhrk01
    mrhrk01 What's a Dremel?
    20 May 2010
