Build Advice Build Fail.... any advice?
Discussion in 'Hardware' started by gem, 6 May 2011.
  1. gem
    gem noob
    23 Mar 2011
    Just got:
    Gigabyte GA-P67A-UD4-B3
    Be Quiet Dark Rock Advanced
    2x 4GB Corsair Vengeance
    and .... YES!
    RAM does not fit for dual channel.... :S
    so what now? return the RAM or is there another solution?
    thanks
  2. Ronaldo 9
    Ronaldo 9 Minimodder
    23 Jun 2010
    So the RAM can not fit in any of the 2 slots nearest the CPU?
  3. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    I would return the RAM.
  4. adam_bagpuss
    24 Apr 2009
    sorry im not quite getting it ?
    The RAM does not fit in the slots ?
    or
    the cooler blocks the first 2 slots and therefore you cant run dual channel ?
    can we get a pic ?
    ive looked at the mobo and cooler i would have thought it fits just fine
  5. Teelzebub
    27 Nov 2009
    Are you sure you have the ram the the right way around because it only fits one way.
  6. murraynt
    murraynt Modder
    6 Jun 2009
    Should fit fine into slot 2 and slot 4. The heatsink will prevent it from fitting into slots 1 and 3.
  7. adam_bagpuss
    24 Apr 2009
    yeah thats what i would think
  8. Zetax
    Zetax What's a Dremel?
    27 Aug 2009
    Lol, same thing happened to me yesterday. Sqme setup, a darkrock and vengeance.
    I just took the heat spreaders off the RAM. Fits perfectly now. But it does void your warranty, so only do it if your not bothered about the warranty.
    For those of you confused. The CPU cooler is so freaking huge, it cover half of the motherboard, preventing any ram with any sort of heat spreader from being inserted. Its rediculous.
  9. adam_bagpuss
    24 Apr 2009
    if thats the case id send the cooler back lol
  10. murraynt
    murraynt Modder
    6 Jun 2009
    Send the ram back for the XM3S stuff?
  11. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    swap for XMS3
  12. gem
    gem noob
    23 Mar 2011
    Exactly this!
    sorry I was a bit frustrated, so the post came out a bit messy...
    Well I followed CPC recommendations and picked up this cooler and corsair vengeance.
    I guess they are great performers those two, but can't really get along ;)
    I'll take some pictures tomorrow morning.
    I guess I have to return the RAM, but to bad I ordered from Germany and I am in Greece....
  13. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Thats why I went for the Tranquillo over the Dark Rock in the end. Careless recommendation from CPC
  14. Teelzebub
    27 Nov 2009
    I did wonder this, Thats why I never take any notice of CPC recommendations tbh
  15. gem
    gem noob
    23 Mar 2011
    OK, so it look like this...:
    What if I cut off a small part of the heatsing?
    Of course warranty will be void, but will it be a dissaster?
  16. Publ!c Enemy
    Publ!c Enemy or Richard for short
    4 Jul 2010
    I wouldn't get into cutting bits off the heatsink, that's asking for trouble, and it doesn't look great. I do the same thing as Zetax did and take off the fancy heat spreader, since it's not really all that useful anyway
  17. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    Its ******** component manufacturers don't think about this type of thing.
    Most motherboards have similar lay outs, most good ram has heat spreaders. You would think the cooler manufacturer would have tested their cooler with some popular products in the market place.
    I have the Bequiet advanced and a P8P67. The vengeance ram goes in but there is less than 1mm clearance - not ideal.
  18. Tangster
    23 May 2009
    If you're going to cut anything, cut the stupid heatspreader off the RAM.
  19. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
  20. gem
    gem noob
    23 Mar 2011
    Sorry, I ment the heatspreader of the RAM as Tangster said, not the CPU Cooler heatsink.
    I guees i can 'trim' it or, remove it as Zetax did.
