Build Advice Build for a friend with £625 budget
Discussion in 'Hardware' started by meandmymouth, 1 Sep 2013.
  1. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    So a friend has asked me to spec and probably build him a PC. His budget is £500 but we'll be getting the parts through work so no VAT. This gives me the £625 budget.
    He's a graphic designer and does most his work on Adobe illustrator (I think) and it will be used for this. It will also be used for gaming.
    He does not need a monitor, peripherals or an OS so I'm just looking at the base unit.
    As he wants to use it for work, I'm swaying towards Intel however, he is a gamer too so a half decent GPU is a must. He'll be running games at 1080p.
    Part of me is thinking I should put him off buying a GPU for a couple months until the new AMD GPU's are available. That should give a bit more budget to play with now.
    What do you think?
  2. djzic
    djzic Bokehlicious!
    8 Nov 2010
  3. meandmymouth
    15 Sep 2009
    I was thinking about lending him a GPU. I have a GT 520 lying around which should keep him going.
