Build Advice Build for this week
Discussion in 'Hardware' started by Xir, 21 Jan 2013.
  1. Xir
    Xir Modder
    26 Apr 2006
    So, it’s time for a new build. (well it’s been time for a few years really) :D
    Thanks to a good cashback-offer on the motherboard, this month is the deadline while I would like to wait a bit for some of the components to come down a bit.
    As I don’t have to much time in the next few months anyway, and we’ll be mainly surfing first, I thought I might buy in two tranches.
    Ah: the obligatory part
    Budget: Well, as cheap as possible really, though not capped.
    Main uses of intended build: Gamin’ surfin’ ****…errrr, gereral family PC + HTPC …Bit calles this the “Gaming Workhorse”
    Parts required: Most
    Previous build information (list details of parts): see sig.
    Monitor resolution: 1920*1080, or 1920*1080+1280*1024, or 3840*1080…for now who knows what in a couple years time
    Storage requirements: yes please
    Will you be overclocking: yes/no (delete as required) Mayhaps
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): good onboard sound
    Extra information about desired system: As quiet as my cheapyness will get me, and secondary HDMI-out.
    Part 1(To be purchased this week)
    197€ - i5-3570K
    125€ - Asus Maximus V Gene (Thx to 25€ cashback)
    38€ - 8GB 2x Kit 1600 DDR3
    87€ - 2TB Ecogreen or similar
    83€ - Win7 64
    Part 2(To be purchased March-April ish)
    NVidia GTX670 (currently 350€)
    SSD Then, hopefully a 256GB one
    Two Questions:
    The SSD,
    buy it now? (Samsung 120GB 840 for 83€) Would save me the hassle of reinstalling later, but the 256GB ones might come down from their current 150€)
    The PSU.
    I don’t want to skimp on it, but I don’t want to pay an unnecessery fortune.
    The Corsair HX650 seems to be recommended here. It’s 103€
    The Corsair TX650 is only 80€, is the non-detachable cables the only difference?
    I’ll take any well known brand that’s quiet really. There are lots on offer for around 80€
    Just to avoid some questions on forehand, yes, there are two things missing:
    No case, I’ll reuse an old one that already has filters and 120mm fans.
    No additional cooler, I don’t plan on overclocking, I buy overclockable parts because in my experience they offer a superior lifetime when not overclocked.
    Besides I can always buy an additional cooler and clock the nuts off it later :D
    Looking forward to your thoughts,
    Xir
  2. Xir
    Xir Modder
    26 Apr 2006
    Hmmm,
    I'll need a SATA DVD-drive, haven't got one. :D
    How would I connect the drives?
    SSD and FDD on SATA6?
    DVD on SATA3?
    or would the FDD "brake" the SSD?
  3. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    FDD? Floppy disk drive?
    Put the optical drive on a SATA 300Mbit/s port as it doesn't support SATA 600Mbit/s anyway, and save the faster ports for your SSDs and HDDs.
    Your build looks pretty good to me. An SSD is a big improvement so get it as soon as possible. As for the power supply, a 550W unit would be plenty. Check out the Seasonic G series as well.
  4. Xir
    Xir Modder
    26 Apr 2006
    Sorry yes, HDD, not FDD :D
    550 Watt's okay? good.
    I'd been checking the PSU'S in the buyers guide, hence the 650W version.
  5. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    There's no difference between the modular/semi-modular/non-modular Corsair series. It mostly down to aesthetics and slightly easier cable management.
    You say you don't want an additional cooler, but if you want a really quiet pc I can highly recommend the Gelid Tranquillo. It's as silent as a mouse with tonsillitis and a bargain at £25! If you do want to overclock at some point, it is also a pretty good cooler
  6. Xir
    Xir Modder
    26 Apr 2006
    Hmmm, Corsairs 550W or the like are not really available, except the “builder” series CX500V3 / CX600V3 or “Gamer series” Corsair GS600 80plus bronze HX and TX start at 650W
    Seasonic G series is out of stock… The M12II-520 80plus bronze is available (and mentioned in the “recommended PSU” section here.
    How about this:
    Be Quiet! Pure Power L8-530W/CM
    Got a good review on Tom’s, supposedly very quiet.
    73€ - Seasonic M12II-520
    70€ - Be Quiet! Pure Power L8-530W/CM
    80€ - Corsair TX650V2
    :confused:
  7. Xir
    Xir Modder
    26 Apr 2006
    ...strange, prices went up since Monday.
    205€ - Intel Core i5-3570K Box, LGA1155
    160€ - ASUS Maximus V GENE, Sockel 1155, mATX, DDR3
    43€ - 8GB-Kit Corsair Vengeance Low Profile schwarz PC3-12800U CL9
    90€ - Samsung SSD 840 120GB SATA 6Gb/s
    87€ - WD Caviar Green 2TB Sata 6Gb/s
    69€ - be quiet! Pure Power L8 CM
    83€ - Microsoft Windows 8 64-Bit (SB-Version)
    736€
    That's 30€ more than Monday! :eeek:
  8. Xir
    Xir Modder
    26 Apr 2006
    The cheaky Bstards :duh:
    If I go through the price search engine, I get mondays pricing.
    If I go directly through the website, I get 5% more...
