Build Advice Build issues and questions
Discussion in 'Hardware' started by MrP, 25 Apr 2020.
  1. MrP
    MrP seeking inspiration
    5 Jul 2007
    Right, am building my new(ish) machine up with some new stuff and some very very old stuff!!
    MSI B450 pro gaming carbon AC
    Ryzen 5 3600
    Coolermaster master liquid lite 240
    16gb Corsair vengence pro RGB
    Corsair 512GB M.2
    AMD R9 280x
    Corsair HX620w (told you it was a newISH build)
    got some hardware and software question as this is my first build in about 6 years, so forgive me if some of these are rather stupid, but I would rather do a few sanity checks.
    I'm running a few blender render to check temps, with pbo enabled, I am seeing temps of 72 plus with the cpu running all core 4.15ghz. Sound normal?
    Also, this is the first time I am running a aio water-cooler. I kind of expected to see temps working slightly differently to a normal air cooler, I thought I would see temps rising and falling more slowly than I am, at the moment when the render completes the temp instantly falls from 70 plus straight to mid 30's idle, I expected to see a drop to say 50 and then a drop while the rad cooled the water further, could some set me straight please :)
    I'll probably be back later with more questions, but thanks for you answers to these
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    This is a common misconception with weatercooling, especially AIO's. They have so little water in them (usually 100-250ml) that your thermal store is really low. If you check the thermal difference between input and output it'll only be a few degrees. They ho no res, so no large body of water to hold heat, they're small, so fluid flows round fast and takes in and dumps heat fast too :) They're far closer to heat pipes, its why something like a Noctua D15 performs basically the same as an AIO, it has the same red surface area as a 240 AIO. Hope this helps :)
  3. MrP
    5 Jul 2007
    Pete,
    That does thanks make sense.
    Do the temps and speed look reasonable?
  4. Bloody_Pete
    11 Aug 2008
    No idea I'm afraid, you'll have to wait for someone who's used the AMD platform to answer that one :)
