Case Mod - In Progress [Build Log] The [P]retty[O]btuse[S]leeper by Duality92
Discussion in 'Project Logs' started by Duality92, 11 Apr 2018.
  1. Duality92
    Duality92 Member
    25 Feb 2015
    Pretty
    Obtuse
    Sleeper
    HARDWARE
    CPU : Intel i5 8600K with Fanless Phanteks PH-TC12LS
    Motherboard : Gigabyte Z370N-Wifi
    RAM : Team Group Nighthawk White 2*8GB 3600/18
    SSD : Crucial MX200 500GB m.2
    GPU : Gigabyte GTX 1070 Mini OC with Li-Heat 30cm B-type riser and 3D Printed mount
    PSU : HDPlex 400W HiFi DC-ATX with brick
    Monitor : 15.6" 1366*768 built in with HP Pavillion 32q 2560*1440 IPS external
    Case : Eclipse 1500C
  2. Duality92
    Duality92 Member
    25 Feb 2015
    So here's the case in all it's glory, it's an Eclipse 1500C Point Of Sales (also called POS), gives you the reason why I choose the name too! :D
    These pictures are after a good bath there was so much dust in there, it needed to go for a dishwasher cycle! pictures are with the monitor disassembled, it was a touch screen TFT 15" monitor, which I won't be using.
  3. Duality92
    Duality92 Member
    25 Feb 2015
    Happy to announce this project will be in collaboration with HDPlex with one of their 400 DC-ATX Hi-Fi power supplies along with a power brick to power it as well as Gigabyte who will be supplying a Z370N-Wifi motherboard and GTX 1070 Mini OC!
  4. Duality92
    Duality92 Member
    25 Feb 2015
    Laptop LCD built into the frame instead of the stock 15" TFT. Looks much crisper than that stock display and will serve well as a secondary display :)
  5. Duality92
    Duality92 Member
    25 Feb 2015
  6. Mojo
    Mojo Well-Known Member
    18 Nov 2011
    Could we have some more details about the controller you're using for the screen?
    Looks like it has hdmi input?
  7. Duality92
    Duality92 Member
    25 Feb 2015
