Build me a comp for $400
Discussion in 'Hardware' started by DaHoboFest, 13 Aug 2004.
  1. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    I want to build a comp for my house here in florida, my max budget is 400, should be able to game to some extent. Monitor not included, but keyboard and mouse needs to be included.
    Preference
    AMD, 512mb, decent gpu, cd rw
    Links and prices on newegg.com
  2. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
  3. psyphen
    psyphen What's a Dremel?
    20 Jul 2004
  4. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
  5. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    oh ****, cd burner
  6. psyphen
    20 Jul 2004
    What happened to the CDRW? //Heh you beat me to the post.
  7. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    go over to tech tv and look up thier 500 gamming rig and just tweak acording to your budget
    now g4tv.com under screen savers :thumb:
    archives maybe down due to the switch but they should be up shortly
  8. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    ok i found one for 24, anything i can replace to make my stuff cheaper?
  9. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
  10. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    :thumb: :thumb: , nice for not much more that 420$, but shipping will cost about 20$, and if you have all the cables necessary no matter if they are the ribbon (your choice), then it should be fine.
  11. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    the total price is 427 not including keyboard or mouse, and would like to get wit hkeyboard and mouse down to 400, should I get an athlon 2000+? Or a different mobo? I don't know anything about mobos. Does the hd, ram, and cpu work with the mobo i listed?
  12. 1st time modder
    21 Dec 2003
    1 way to decrease the price would be to downsize the 9600 to a 9600SE, but since this is a gaming rig you shouldnt switch.
  13. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    what's the best video card for under 100, nvidia is ok, how is it comparible to the 9600 pro
  14. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    would going with intel be cheaper, (cpu and mobo)? What would be comparable to an AMD 2500 Barton
  15. 1st time modder
    21 Dec 2003
    no going intel would be more expensive. Mobos are about the same price for each but the intel processors are much more expensive.
  16. 1st time modder
    21 Dec 2003
  17. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    Well, I acytually found a way to brign down the price, I'm gonna ship my old RAM, pc2100 512mb and a monitor. so that takes 70 dollars off my list. I don't want to change video cards I decided. So, since i don't know anything about mobos, is the one i selected good for gaming? compatible with ddr pc2100 RAM, compatible with the AMD 2500?
  18. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
  19. Firehed
    15 Feb 2004
    All of them, refurbished stuff on newegg is just the card in an antistatic bag. So IDE anyways.
    The 2500+ wants PC2700/DDR333 ram, and often times running an AMD system with a divider (which you would need to unless the ram overclocks well) will cause it to be unstable. Theoretically it would work though.
    http://www.newegg.com/app/ViewProductDesc.asp?description=13-157-022&depa=1
    That mobo is a little cheaper and would come with cables. $44
    http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-379&depa=1
    2500+ =$89
    http://www.newegg.com/app/ViewProductDesc.asp?description=22-140-133&depa=1
    40gb HD $45
    http://www.newegg.com/app/viewProductDesc.asp?description=11-145-026&depa=0&manufactory=BROWSE
    Case + PSU = $26
    http://www.newegg.com/app/ViewProductDesc.asp?description=14-240-014&depa=1
    9600pro = $111
    http://www.newegg.com/app/ViewProductDesc.asp?description=20-211-119&depa=1
    512mb ram = $73
    http://www.newegg.com/app/ViewProductDesc.asp?description=27-182-011&depa=1
    52x CDRW = $25
    That's $413 plus some shipping... that's about as close to $400 as you'll get unless you really take a hit on the video card. You could get a 9550 but I think it's worth the extra $15 or so, unless your budget is THAT tight
  20. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    no, I have pc 2100, I want to use that pc2100. So I need a mobo that is compatible with that. I'm not even sure i;m gonna get the comp. MY mom is trying to persuade me not to.
