Bits Build your own server
Discussion in 'Article Discussion' started by Da Dego, 5 Jun 2007.
  1. Glider
    Glider /dev/null
    2 Aug 2005
    It is indeed installed, does it work when you type 'x11vnc'? Maybe the userrights are fixed in the new release.
  2. B_Dauterive
    B_Dauterive What's a Dremel?
    23 Dec 2008
    I have since got it working (sorta) and have moved on to installing Putty and UltraVnc. Everything went swimmingly with Putty but for some reason Ultravnc viewer cannot connect to the server. I keep getting a: " the plug-in cannot be loaded. etc" message.
  3. statmonkey
    statmonkey What's a Dremel?
    5 Nov 2007
    Amazing this is still alive but deservedly so. At this point I have replicated the first two of these tutorials for (and with) 7 different friends and built the router box for two people besides myself. Of all the tutorials I have come across over the years this is certainly one of the most complete and most useful. Essentially I have been able to apply it to Ubuntu 7.1 - 8.1 and even tweaked my way around with a fedora box using the basics outlined here. Really hope there will be more things like this in the future. Thanks again Glider.
  4. Glider
    Glider /dev/null
    2 Aug 2005
    Mail your suggestions to Tim or another staff member ;)
  5. statmonkey
    5 Nov 2007
    Hmm, how to say this in a politically correct manner ... I believe the success and value of these tutorials lies in the way they were written and laid out and all due to the author. I don't remember how I stumbled across the first article but became a reader of this site due to it and the follow ups. I hope Glider, that you will continue to write this type of thing, you are obviously very good at it and have helped a lot of people. If you do write other things, I hope I can find them ... I read somewhere you were leaving the site and if it is true that is really a loss for bit-tech.
  6. tookie07
    tookie07 What's a Dremel?
    19 Jan 2009
    Hi there, nice guide, i am getting an error when i try to connect to my server using Ultra VNC Viewer. It keeps saying Connection failed - error reading protocol version, possible causes: - you've forgotten to select a DSMPlugin and the server uses a DSMPlugin. it shows me this error after i type in the password even though i have use DSMPlugin checked.
  7. tookie07
    19 Jan 2009
  8. Doomus
    Doomus What's a Dremel?
    19 Jan 2009
    I am having a problem with the /proftpd/proftpd.conf section, then i try to reboot the ftp server, it tells me that im missing an augment on line 99 under <Directory>, any idea on what my problem is?
    great stuff btw ^^
  9. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Sure its not meant to read argument? In which case post your (anonymised) proftpd.conf and we can have a look.
  10. Doomus
    19 Jan 2009
    its an exact copy paste of the directed information, i am also using a newer version of Xubuntu than the guide i beleive, but in any case:
    # /etc/proftpd.conf -- This is a basic ProFTPD configuration file.
    # To really apply changes reload proftpd after modifications.
    ServerName "FTP Server"
    Serverident on "FTP"
    ServerType standalone
    DeferWelcome off
    TimesGMT off
    MultilineRFC2228 on
    #DefaultServer on
    ShowSymlinks on
    TimeoutNoTransfer 600
    TimeoutStalled 600
    TimeoutIdle 1200
    DisplayLogin welcome.msg
    DisplayChdir .message
    ListOptions "-l"
    DenyFilter \*.*/
    AllowForeignAddress on
    AllowRetrieveRestart on
    # Uncomment this if you are using NIS or LDAP to retrieve passwords:
    #PersistentPasswd off
    # Uncomment this if you would use TLS module:
    #TLSEngine on
    # Uncomment this if you would use quota module:
    #Quotas on
    # Uncomment this if you would use ratio module:
    #Ratios on
    # Port 21 is the standard FTP port.
    Port 21
    SocketBindTight on
    PassivePorts 11000 20000
    # To prevent DoS attacks, set the maximum number of child processes
    # to 30. If you need to allow more than 30 concurrent connections
    # at once, simply increase this value. Note that this ONLY works
    # in standalone mode, in inetd mode you should use an inetd server
    # that allows you to limit maximum number of processes per service
    # (such as xinetd)
    MaxInstances 30
    # Set the user and group that the server normally runs at.
    User nobody
    Group nogroup
    # Umask 022 is a good standard umask to prevent new files and dirs
    # (second parm) from being group and world writable.
    Umask 022 022
    # Normally, we want files to be overwriteable.
    AllowOverwrite on
    AllowStoreRestart on
    # Speed up the server, no DNS lookups, just plain ip's. Turn off when being hax0r3d.
    UseReverseDNS off
    IdentLookups off
    DefaultRoot ~
    ExtendedLog /var/log/proftpd.all ALL
    # Delay engine reduces impact of the so-called Timing Attack described in
    # http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02
    # It is on by default.
    DelayEngine off
    <Anonymous ~ftp>
    User ftp
    Group nogroup
    UserAlias anonymous ftp
    DirFakeUser on ftp
    DirFakeGroup on ftp
    RequireValidShell off
    MaxClients 10
    DisplayChdir .message <?-my version did not like DisplayFirstChdir, so i swited it to this and it works ->
    AccessGrantMsg "Anonymous access granted for user %u connecting."
    MaxClientsPerHost 1
    <Directory>
    #DenyAll
    TransferRate RETR 50
    <Limit WRITE>
    DenyAll
    </Limit>
    </Directory>
    Any help would be much apppritiated, and thsnks a bunch ^^
  11. JrRRr
    JrRRr Minecraft addict
    27 Mar 2003
    Same problem i discovered just now..
    Problem 1: <Directory> should be <Directory *>
    Problem 2: Ad a line after the last line (</Directory>) that reads </Anonymous> to close the argument correctly.
  12. Xjagdog
    Xjagdog What's a Dremel?
    15 Feb 2009
    Hi Folks.
    I am a total newbie to Linux but thanks to this great article I am enjoying having a go at building a server with Xubuntu 8.10 or I was till I screwed up the network !!!.
    I got as far as connecting with ultravnc from another windows pc on the network and connecting to it from the internet from a friends pc. but somewhere along the way after a restart i think, the router gave the server a different IP address which stopped me connecting to it. So i decided to set the server to a static IP ( boy was that a daft idea ) ever since messing with the IP i am getting a red cross on the network icon and i can't get rid of it by changing the network back to DHCP.
    I would be grateful for any advice you could give.
  13. Andy Mc
    Andy Mc Modder
    23 May 2002
    When setting up the server did you configure it to have a static IP address? If so was it the same one as you have since setup in the router? If not then this may be your issue.
    At the terminal type:
    ifconfig
    and make sure that the entry for eth0 is the same IP as the one you have configured the router, if not then you will need to change the IP that your router is giving the server.
  14. Xjagdog
    15 Feb 2009
    Thanks for the reply.
    It looks like you are right, I set the server up without a static IP.
    I found the answer on the ubuntugeek.com website which said there is a bug in Gnome network manager ( that is what I was using ) so I removed it and followed the instructions to set a static IP and it all worked fine no problem.
    Thanks again for the help, I am sure to be back the next time I trip up.
  15. cmagana523
    cmagana523 What's a Dremel?
    19 Feb 2009
    Hello
    Another newbie here and I am having some trouble with this server deal. I got as far as configuring samba and creating a username and password at this point according to the article I should be able to connect to the server from another pc. My server is an old desktop and the other pc I have is a laptop running XP home if that helps any.
    Thanks in advance for any help
  16. TheMutt
    TheMutt What's a Dremel?
    19 Feb 2009
    I was getting an error with VNC saying something about DMS I believe, but after some reading I determined I hadn't created the .vnc directory, so I did that, now when I try to connect with VNC, it just says "Failed to connect to server !"
    I can't figure out why. I'm new to Linux and any help is appreciated.
    (I know this isn't a very descriptive error, but if there are commands you want me to run and post the output of, I'll be happy to do that as quickly as I can.)
    Thanks in advance
  17. Glider
    Glider /dev/null
    2 Aug 2005
    Can you post the output of the following commands?
    Code:
    id
    ls -al ~/.vnc
  18. TheMutt
    19 Feb 2009
    will do as soon as I get home. I'm at class right now.
  19. TheMutt
    19 Feb 2009
    ok here's the output
    Code:
    nick@mutt-server:~$ id
    uid=1000(nick) gid=1000(nick) groups=4(adm),20(dialout),24(cdrom),46(plugdev),112(lpadmin),120(admin),122(sambashare),1000(nick)
    nick@mutt-server:~$ ls -al ~/.vnc
    total 16
    drwxr-xr-x  2 nick nick 4096 2009-02-18 22:37 .
    drwxr-xr-x 18 nick nick 4096 2009-02-19 17:34 ..
    -rw-------  1 nick nick    8 2009-02-18 22:26 passwd
    -rw-r--r--  1 nick nick    5 2009-02-19 17:35 port
    nick@mutt-server:~$
  20. TheMutt
    19 Feb 2009
    It seems to be working now. I'm not sure what changed, but I'm not complaining.
    I do have a question though. It seems after I've downloaded the a file via torrent onto the server, to open it on my other computer, I have to download the file on there, from the server (if only in a temp file). The point is, when I do this, it takes up space and takes time to transfer the file over.
    However, I noticed this doesn't seem to happen when I access files through opening the a folder location of \\(ip address)\homes. and I seem to be able to run files directly from it, rather than transfering to the computer I'm using... If this is the case, can I change it so that the torrents download to that folder without any reprecussions?
    I'm fairly confident I could change the download location, I just want to make sure my assumptions about how this works are correct.
Tags: Add Tags
