Hardware Build your own Steam Box
Discussion in 'Article Discussion' started by brumgrunt, 18 Jul 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Canon
    Canon Reformed
    19 Jul 2010
    I once did this crazy thing, I installed steam on my PC, it was already capable of running steam and all its games, I had space, it could even do all sorts of other things too. I saved myself a ton of money, time, physical space and I wasn't wasting electricity.
    Madness, I know.
  3. Edwards
    Edwards Minimodder
    8 Oct 2010
    I've got my PC wired to my TV with an HDMI cable, if I want to take steam to my TV I just change the main display on my PC and move to the sofa, controller in hand :)
  4. Baz
    Baz I work for Corsair
    13 Jan 2005
    The point of the article is for a set-top-box emulating system, as the mythical steam box would be.
  5. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Yeah but let's be honest, it's a bit rubbish isn't it? It's a really awful build with a poor allocation of budget, there are a lot of better options if you want to use steam for gaming on your TV. (EDIT: And I mean specifically in SFF as well).
  6. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    Ah, sorry we hadn't seen your detailed report Zinfandel. Showing us how you carefully selected the appropriate components based on merit, cost, looks and performance. I also missed how you carefully explained how you built the system with heat dispensation in mind along with maintaining performance whilst keeping this as quiet as possible. I also missed your test results showing your systems performance in the relevant games selected and the comparisons at different settings. It must have taken you ages to complete.
    Of course, once we've seen all that, we can happily agree with your previous comment :p
  7. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Indeed, as long as you don't mind increasing the size overall you can end up with something much more potent:
    Case - Silverstone Sugo SU05 w/450w PSU - £120
    MB - Asus H61 ITX - £60
    CPU - i3 2120 - £90
    Memory - 4GB DDR3 1600MT/s - £20
    GPU - HD6850 - £84
    HD - 120GB SSD - £70
    OD - DVDRW - £12
    Total spend is a smidge under £460.
    Whilst the SU05 is overall larger it is hardly a behemoth. Personally I think the size trade off is worth it to get something that has considerably more gaming power.
    If all you want to do is play the games suggested with a controller, surely a console is a better bet anyway?
    EDIT: Thinking about it if you want something small that can still game what about a laptop? PC Specialist offer the Inferno 11.6" laptop with a i5-3210M / GT650M (GT640) for a little over £600 with Windows 7 x64. Plug it into a TV and you have a steam box yet you also have the advantage of being able to use it / game on it elsewhere easily.
  8. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    Couldn't agree more, even with off the shelf components I had thought Bit Tech would have been able to come up with something far better.
    The focus on SFF PC's on BT lately has been refreshing but also somewhat frustrating and I am really getting the urge to mod something that is not only minimalistically small but also whisper quiet and as close to being as powerful as a full size box.
    It is still in the early planning stages with separate compartments to remove heat directly out of the case but have not decided which of 2 main designs to run with atm. Will have to get them drawn up in SketchUp and posted on the forums for some initial thoughts and feedback I think.
  9. Jqim
    Jqim What's a Dremel?
    10 Jan 2011
    So why no Llano?
  10. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Sorry, I was quite reserved earlier, here's what I actually think.
    That is one of the most awful builds I have ever seen and it's shameful that it's on the front page.
    If there's a member on this forum who posts advice in the HW forum who couldn't put together a better selection of hardware for that budget for the purpose of gaming on a TV then they shouldn't be giving advice.
    Also, who doesn't have a full HD tv these days? Ok probably a lot of people, but most techies will probably have a full HD TV.
    Yeah, this might be the worst article I've ever seen on Bit Tech.
    EDIT: Which is a massive shame because I actually quite like the idea of a Steam box.
  11. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    This. Surely a Llano ITX motherboard and a A3870K will perform better in games, use similar or less power, be cheaper and so on...
  12. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    Is it my imagination, or are there lots of pictures missing from this article?
  13. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    Yeah id have probably gone with the same, then again im dieing for someone to commision me a Liano build!
    Havent had a chance to play yet : (
    If i remmeber correctly you ca pair with a low end 5XXX/6XXXX Series card to for some hybrid crossfire action?
    As shown in this unboxing
    http://www.youtube.com/watch?v=uLJcAyF5cC8&feature=plcp
  14. Parge
    16 Jul 2010
    A far better build.
    I agree, however small it is that case is godawful, and the 96C CPU temps smacks of bad component choices. Why not pick up a HTPC case like the SilverStone LC03S-V which is only £59.99 at Scan. It would fit in perfectly with the rest of someones AV gear and provide better temps and acoustic dampening that that terrible Cheiftech chassis.
    Again - an 3870k is another obvious choice here! An ITX A75 mobo can be had for £70, and the CPU itself for around £80 and it will play most basic games.
    We are a tough crowd to please!
  15. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    And isn't page 1 just pages 2-5 combined?
  16. CozaMcCoza
    CozaMcCoza What's a Dremel?
    29 May 2008
    10m HDMI cable and wireless controller for XBox360 and hook it up to your PC that way. Minimal cost and no hardware constraints as your main rig would be used...
  17. Combatus
    16 Feb 2009
    I've just edited it as we had a paragraph or two copied over. Sorted now!
  18. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    The new Cooler Master Elite 120 case at £34.78 from Scan, that get's my vote for a case. And it would be nice to see an AMD build for SOMETHING..., especially as you can do the hybrid xfire thing...
  19. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    Love the idea, hate the execution. For the price you've paid here, an extra 1 or £200 pounds could have built you a fully fledged system. I know that's kinda missing the point, but why limit yourself when for just a little bit extra, you could have so much more?
  20. longweight
    7 May 2011
    Why aren't the benchmarks run at 1080?
Tags: Add Tags
