Cases Building a case for air
Discussion in 'Hardware' started by sp4nky, 25 Jul 2010.
  1. sp4nky
    sp4nky BF3: Aardfrith WoT: McGubbins
    15 Jul 2009
    I'm building a PC for only the second time and the first didn't go well - the first one I managed to fry. Since then I've told a local PC shop which components to buy and had them build it for me. Now that I'm a little older and a little wiser, I want to avoid that costly option.
    I've got everything except the case and that's giving me a little headache. I had plumped for the CM690 Advanced II but it didn't come - bad stock or something - so now I'm looking for an alternative. I've got the original version of the Antec 900 and it doesn't have much length-ways room for working between the graphics card (bought a 5850) and the hard drives, so I'm ideally searching for something bigger
    My budget is £100. What can you recommend?
  2. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    The CM690 II is a great all-rounder case at this price point so couldn't you just order it from another store? However there are some other alternatives that stand out at this price point.
    Best Value:
    Xigmatek Utgard
    Best Cooling:
    Antec Nine Hundred Two
    Cooler Master HAF 922
    Best Noise Levels:
    Fractal Design R2
    I'd take your pick out of these after reading the reviews & deciding whwat's most important for you in a case.
  3. Jipa
    5 Feb 2004
    Bigger than Antec 900? 1200 or HAF932. Really, though, why on earth would you even need space between the graphics and the hdd-cage? You can mount the HDDs elsewhere...
  4. Telltale Boy
    3 May 2010
    Yeah, if you really do need a large case then these are your best bets as they're not too far off your budget.
  5. sp4nky
    15 Jul 2009
    What's important for me is having tool-free access, especially for fitting a new HDD or a SSD. Also space for fitting the power connectors and general cable management around the graphics card. This excludes the 902, which is a disappointment for me, since I like its styling.
    I'll try to find another CM690 II, I guess. The combination of the mesh front, the tool-free drives and so many fan mounts makes it a winner for me.
  6. sp4nky
    15 Jul 2009
    Why do I need that space? Fat fingers mean I've had trouble fitting the power connectors on my HD4870 card in my 900.
  7. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    What was your last case?
    CM690II is in stock at Scan
    I don't really see why you need anything bigger than a 900, a 5850 is 9.5" (same as a 4870) so any well designed Mid Tower should accommodate and the CM 690II sports removable lower drive bays for more space
    But here's some advice should you chose the CM690 - fill all the fan bays but buy a fan controller, then reduce all the fans to about half speed, I have the original case and most of the fans are disconnected otherwise it would be impossible to sit near
  8. sp4nky
    15 Jul 2009
    I ordered a CM690 II from Scan. They sent me a CM690 original, which is going back, and said they've got a stock problem. This explains why they're both the same price, I think.
    Good point about the fan controller. I've not had one of those before but I'll look at them.
  9. Telltale Boy
    3 May 2010
    You could buy it from Ebuyer for only a little bit more & it also has free delivery.
  10. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
  11. Telltale Boy
    3 May 2010
    I know, I was just mentioning that because he said that he was having issues getting it from scan & the only other places he'd probably be able to get free delivery are EBuyer & CCL.
  12. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    You can fit four HDDs no problem in my Antec 900 with ease and no risk of blocking the graphics card (unless it's some crazy triple slot cooler). My 4870 isn't near the HDD cages so I can fit the full six in there if I wanted to easily.
    (My 4870 has power connectors pointing toward the side of the case so they're even less of an issue, I consider power sockets parallel to the PCB to be an annoying design flaw.)
  13. Elton
    23 Jan 2009
    Storm Sniper or the HAF922>Antec 900.
    WIth that said if you want a gigantic case, use the 932, even if it's hideous.
  14. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I love my HAF 932. The main reason is wiring up, the back pannel has a outward bulge which allows large cable bundles to be easily routed and none of the forcing the door on to make them fit. The only issues with it is the lack of dust filters, but these can be easily modded with moddling mesh and tights :)
  15. sp4nky
    15 Jul 2009
    Mine has power connectors on the end, so sticking into one of the HDD cages. I guess I could remove the cage - hadn't thought of that before. However I want something new, since I've got all the other components new.
    Come Friday, aka payday, I'll toss a coin between the CM690 II and the HAF 932.
  16. sp4nky
    15 Jul 2009
    My budget just got extended to £150. This looks like the perfect case for me.
  17. Telltale Boy
    3 May 2010
    The HAF X looks great if you like the aesthetics. Persoanlly I don't so I'd much rather go with the ATCS 840 or a Liani-Li.
  18. Bloody_Pete
    11 Aug 2008
    HAF X is the bigger brother of the ATCS. Its either or really, no one cases come into it in my opinion
  19. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Looks like a solid choice to me
