Planning Building a custom reservoir
Discussion in 'Modding' started by TheP, 9 Oct 2012.
  1. TheP
    TheP What's a Dremel?
    9 Oct 2012
    Sorry for my bad english
    Well.....im planning to build a custom case and maybe a custom reservoir.
    First things first.
    My case should be like a watermill and what do watermills have...right, a whater wheel (and in this case its not just decoration, but part of my water cooling circuit).
    So before i start sketching there is the question for the right material for my wheel.
    Should i use acrylic (like for the rest of my reservoir) and maybe paint it with waterproof colour or to be more "realistic" use some impregnated wooden parts.
  2. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    I suppose it depends how realistic you are planning on making the final case. An all plastic version would look futuristic and 'clean', but one incorporating wooden parts and a more scale-realistic finish would look great too.
    Depends what your vision for the whole thing is really...
  3. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    Hope you would implement dual loop for your res..
    I mean, one loop using real PC coolant and other loop using just plain water. The case would be cooling the real pc coolant with plain water.
    OR if you prefer watermill you pc coolant?
    wood with coating would be best.. dark colored wood (with dark clear wood coating paint).
  4. TheP
    9 Oct 2012
    So....i try to make small and fast picture (paint rocks :D ) to describe roughly how it could look like
    Well....dimensions are off, but my idea is as follows:
    The coolant will flow on a slope (if the exit is directly above the slope or somehow on the side will be worked out). From slope it will flow on the wheel. Both wheel and slope are made of wood. And from the wheel it will flow directly to my reservoir (made out of acrylic for better possibilities for connections) and from there back to the pump.
    Now I don't know....will such a open system cause much trouble for a coolant circuit. If yes I would make a closed reservoir nearly completely out of acrylic and only the wheel out of wood. I don't think that this way there would be any problems with the tightness
  5. SuicideNeil
    17 Aug 2009
    I was thinking more about how the whole case will look, and how this fits in with the theme...
    An open reservoir is no problem, you'd just have to top it up occasionally due to evaporation. Also consider that a small wheel with a reasonably high rate of flow will result in the wheel spinning quite fast and water splashing everywhere, so the wheel needs to be well 'fenced in', not sitting above or level with the top of the reservoir.
  6. Parge
    16 Jul 2010
    Also worth remembering that splashing water creates a lot of noise, so you can't expect a silent build.
  7. jay2
    3 Oct 2012
    a mind calming noise, better than those Delta Fans :D
    @TheP, i dont know whether you read my comment above, but i suggest you use 2 loop with Heat exchengar between those loop. And you may use plain water as open system, open reservoir, watermill or even a waterfall as you wish. Without having coolant circuit problems :eyebrow:
    but remember, moss love moisture.. you'll neet to shut sealed your PC to prevent high moisture level.. perhaps some silica gell are needed..
    umm.. am I thinking too far?
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Look up "bong cooling"
    it's an interesting subject and your res kinda fits it
  9. TheP
    9 Oct 2012
    Ok....
    @SuicideNeil: The whole concept is, a case looking like some whatermill (with some nordic or asian touch). So a whaterwheel would fit nice to the concept. And the wheel would be a lot bigger then it look like on my fast scribbling.
    @jay2: if you can make a little sketch of how your circuit idea will work then i can understand more ( i can hardly imagine something from just words)
  10. TheP
    9 Oct 2012
    Ok.....read through many different sites, looked at some other custom reservoirs and came to one thing.....a completely closed one is the best thing.
    So the material depends on one thing...glueing.
    Is there a possibility to glue mdf on acrylic without any glue-traces left....this would be my slope. And the wheel would be hold by some sort of bearing.
    Well....if I use coated mdf (waterproof) then there would there be any severe problems if i use it in my cooling circuit?
  11. jay2
    3 Oct 2012
  12. TheP
    9 Oct 2012
    Thanks jay.
    Now its a little bit clearer......but one "problem" (or just bad research) is left: what exchanger would u use for it?
    You have suggested to use one exchanger for both circuits, but all the exchangers i have found have one way in and one way out.
  13. SuicideNeil
    17 Aug 2009
    I would imagine the heat exchanger as being like a reservoir / water tank; the real coolant enters the tank through a metal tube which is a spiral, running top to bottom and then exiting again. The plain water fills the tank through the top and exits the bottom. The 2 circuits are totally separate so the coolant and water do not mix, but the coolant is able to shed its heat through the piping into the water, which then sheds its heat in a separate radiator that is connected to the water wheel & its reservoir.
    Rather complicated set up really...
  14. TheP
    9 Oct 2012
    Realy complicated ^^
    Well....then i start sketching what is going to take a while and then i will see how i will solve this whole cray sh*t
  15. jay2
    3 Oct 2012
    Yup, that would be complecated and traditional..
    And that kind of HE (heat exchanger) is expensive. Bending a copper tube into spiral or multiloop (radiator style) is not easy and require special tool.
    There are several other kinds of HE nowadays like Plate Frame HE and Shell Tube HE. But more complicated and more expensive. I believe there is no small size HE available for PC scale.
    Bad research :) try searching Plate Frame HE or Shell Tube HE.
    Dont blame me if i'm thinking cheapskately, Yes I'm Poor :wallbash:, but trust me, I'm engineer :geek:
    some ms.paint arts :rock: link
    You can build a water tank like an aquarium and use 2 (or more) Aluminium bottle as PC coolant reservoir. Just submerge your PC coolant res in that aquarium and you're done.
    Aluminium bottle can act as heat exchanger to transfer heat from PC coolant to water. And you can play with that water to create watermills or anything.
    I can imagine a more complex but beautiful design and post images for you, if only i can plug a thumb drive to my brain.
  16. TheP
    9 Oct 2012
    Jay2.....if you found a method to plug a drive to your brain....tell me, i need that too :D
    Well....as i said thanks for all those inspirations. How i will do it at last, will be worked out when i go to designing. And unless i cant get the design out of my head via pluging a drive to my brain, it will take some time -.-
    So, if its good enough i start posting it
