Modding Building a large(ish) perspex cuboid reservoir
Discussion in 'Modding' started by Theo, 31 Aug 2003.
  1. Theo
    Theo What's a Dremel?
    12 Jun 2003
    As part of my current cooling project, I plan on submerging an eheim 1250 into a reservoir about 300x200x300 (LxWxH) millimetres. I have a nice amount of 3mm perspex, which feels nice and rigid enough for what I have planned. The reservoir will be completely sealed, bar entree/exit holes and a fill-hole which will be sealed with a plug of some sort.
    Saying this, I have actually very little clue as how I should go about building it. :clap:
    I'm going to measure out and cut everything tomorrow, that's the easy bit. Then I plan to go to B&Q to get some nice woodstain for a door. So anything I might need to build the reservoir will be bought then (if anyone could point something out for me please).
    So erm.. help, please! :wallbash:
  2. 1398342003
    1398342003 Ubermodder
    2 Sep 2002
    Get a 90° inside angle (the inside of an L)
    Sand the contact areas, and glue them with some ABS epoxy
    Clamp them in place on the L
    Repeat
    If you have enough material left over, make a hollow brace for the container.
    Use silicon sealant on the inside for leak proofing
  3. Theo
    12 Jun 2003
    Thanks chap, think I'm on the right track now.. Would it be worth routing a 1mm groove in which to slide the piece in to create a larger surface area? Or am I just getting a little carried away?
  4. 1398342003
    2 Sep 2002
    A 1mm groove will make little or no difference. You might try thicker material, or even putting an extra sheet on the bottom.
