Building a Media Center
Discussion in 'Hardware' started by Xhiz, 17 May 2005.
  1. Xhiz
    Xhiz What's a Dremel?
    28 Oct 2004
    Hey I was thinking of building myself a cheap media center but I can not find the right case.... I found a HiperMedia one but im not 100% sure on that because I can not find information or reviews on it so I don't know how many PCI space it has in the back and stuff.
    Does anyone know a nice looking yet affordable media center case hopefully under £60?
    Or does anyone have more information on the HiperMedia case I found... I found it on scan.co.uk - HiperMedia Chassis, Small Form Factor(AMD Validated) Matt Silver Finish, for Micro-Atx/Mini-Itx MoBo....
  2. Guest-16
    Guest-16 Guest
  3. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    First off make sure youre using a very low rise heatsink-and preferably, a lower clocked, low heat production CPU in order to reduce the risk of the thing frying itself. Personally, I think an AMD Sempron 2600+ for socket 754 would fit the bill pretty well, combined with 512 megs of RAM and a nice big hard drive :)
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    If its the case I've seen there, you'll need laptop sized drives. slimline optical & 2.5" HDD
  5. RotoSequence
    6 Jan 2004
    Certainly doesnt look that way to me :eyebrow:
  6. bwgames
    bwgames Minimodder
    6 Dec 2004
    I can recommend this Chenbro PC805 one (http://www.chenbro.com.tw/product/product_preview.php?pid=76).
    Stick it on its side, and you have a nice media PC case. Its what I use :)
    Get a black DVD drive, and it looks amazing.
    Can fit two HDDs in, a floppy or 3rd HDD, and a 5.25" drive. As well as a mATX mobo.
  7. Xhiz
    28 Oct 2004
    That is exactly what was going in, you read my mind :eeek: but a Socket A :D
    Ill take a look on that review that you posted Bindibadgi and bwgames I had been looking at that case too but I wasn't quite sure.
