Building a new pc, got some definates down but need some advice
Discussion in 'Tech Support' started by geode, 8 Mar 2007.
  1. geode
    geode What's a Dremel?
    8 Mar 2007
    I am currently planning to use msi's k6speedster series (info here: http://www.msi.com.tw/program/products/server/svr/pro_svr_detail.php?UID=637
    i was thinking of using 2 dual-core opterons, but am not sure 1: if the ram has to be paired, and what sizes or ram i can use - as in can i use 4 gig sticks, or is it limited to 2 gig stick? Also, not sure if I want o go with xista or xp for my primary OS - althouigh i'm gonna be doing a dual-boot with various flavors of linux till i find the one i like best.
  2. airchie
    airchie What's a Dremel?
    22 Mar 2005
    From your link:
    So it seems 1GB sticks will be fine.
    I would still steer clear of vista personally but plenty of people are using it and starting to like it.
  3. geode
    8 Mar 2007
    so that would be 8 separate 2 gig sticks for a total of 16 gigs then, right? Also, it will be july at least before i get to the point of installing the OS, do you think thats sufficient time for them to patch vista enough for it to be worthwhile?
    Also i have heard vista does not recognize multiple processors right - like on the board i listed it would only see one of the 2 processors - is there any validity to this?
  4. airchie
    22 Mar 2005
    I'm pretty sure Vista will be capable of seeing multiple CPUs.
    XP can do it so for Vista to not be able would be stupid.
    It may depend on which version of Vista you get as to whether it allows you to install on a multi-proc machine.
    What you planning to use this machine for?
  5. geode
    8 Mar 2007
    i was hoping to use vista ultimate
  6. geode
    8 Mar 2007
    oh, sorry, missed the question lol - i will be running http, ftp, and mail servers, as well as dedicated game servers, audio and video editing,compiling and burning, file downloading, databases of several types for different things each, structural design, graphics design, running security cameras and recording their output as needed (im wanting to set it up where the record funtion of the security cameras are motion-activated, then record to the hdd, and learning then doing programming. Oh, and of course gaming :)
  7. Rage.
    Rage. What's a Dremel?
    3 Mar 2007
    vista is slow, but if ure after security, vista is for you.. i dont like it much only because of security.. however its pretty good.
  8. geode
    8 Mar 2007
    what did you mean vista is slow? would it run all that (and my messengers of course) without lagging? if i put in 4 gigs of ram or better? (im loking at either 8 or 16 gigs right now, just havent decided which
  9. samkiller42
    25 Apr 2006
    Vista wont be slow with 2 opterons in it, and especially with 4gb of ram, however you will need some sort of decent GFX for vista to be worth while.
    Sam
  10. geode
    8 Mar 2007
    i know i need to get a new video card for the system, but have no clue where to look, though i heard something about sli vid cards and linking them....any real benefit to doing that? and any vid card recommendations?
  11. DougEdey
    5 Jul 2005
    Depends on your gaming resolution.
    Nvidia G80: if you're not going to be gaming at more then 1280x1024 for a long time get a 640MB 8800GTS, if you're going larger/want more life go for 8800GTX 768MB.
    But the ATi competitor to nVidia's G80 is the R600, which rumours has as being better by a lot. But no-one *actually* knows.
  12. geode
    8 Mar 2007
    well, i know i will be doing a lot of gaming once i have the system up, and i do like using the higher resolutions, also i know i need the tvout capacity. Also, i have to have a tv capture card, but i know there are some vid cards with integrated capture cards - are the all-in-one vid cards worth it or is it actually better to get teh capture card and vid card separate?
  13. culley
    culley What's a Dremel?
    12 Jul 2006
    I always wonder would your system be running at double the CPU speed for instance say i press window+pause would my CPU speed show as(2xAMD37002.21GHz) 4.22GHz or would it show up as 2 seperate CPU's.
  14. geode
    8 Mar 2007
    I can't say from experience as i dont have the system built yet, but a friend of mine has a dual-core, and it shows up in the task manager as searate processors
