Other Building a prop
Discussion in 'Tech Support' started by Canon, 4 Feb 2012.
  1. Canon
    Canon Reformed
    19 Jul 2010
    Ok, been tasked with building a prop bomb. It has to be housed in a project box, be loud enough to be heard in a large room with plenty of dividing walls, and activated by a toggle + button switch.
    It needs to be done on a budget so unfortunately no micro controllers and LCDs, keypads maybe.
    I was considering a loud kitchen timer, but it would have to be of a certain standard where I could remove the casing and solder before fitting in the box.
    Does anyone have any ideas for a device that would be ready to use, I can set a time on, and butcher?
    A really odd bloody question, I know.
  2. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    The FBI are watching your thread :)
