Electronics building an ad-hoc flyback supply.
Discussion in 'Modding' started by OtakuHawk, 11 Feb 2007.
  1. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    hey folks. i'm trying to cobble together an HV power supply from a bunch of things. and i'm not sure if it'll work. I really don't have a full lab setup to test things out with.
    the inside of the dimmer looks kinda like this
    am I missing anything big here? or will I be able to draw a decent arc from this? (assuming I don't smoke the flyback xfrmr secondary) the first transformer is current-limited to 2.5 A on the 2ndary, so I'm not too worried about it.
  2. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    it'll make something, but the dimmer isnt really meant for inductive loads, so the componets inside of it, may start to avalance and not allow your inductive spike to grow very large.
  3. OtakuHawk
    30 Apr 2003
    so put a few HV diodes between the dimmer and flyback primary?
  4. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    You might have better luck with a variac (variable ratio autotransformer) but be aware that it will not provide any isolation from the mains.
    Moriquendi
  5. ConKbot of Doom
    2 Jul 2003
  6. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    I might be wrong, but I think flybacks are meant to be driven at very high frequency in order to generate their rated output voltage. If you try and run them from 50 or 60hz mains power you might burn out the flyback.
  7. OtakuHawk
    30 Apr 2003
    that's what the dimmer is for. it's an SCR that turns the circuit off halfway through the waveform, giving me a nice HF falling edge.
  8. ConKbot of Doom
    2 Jul 2003
    Dimmers turn off at the zero crossing, and turn on partially though the cycle, but the 4hv wiki entry says you can use a dimmer an a series cap to limit current so, do a little searching on cap value to use, and give it a shot.
  9. JazX101
    JazX101 What's a Dremel?
    27 Jun 2004
    Lo!
    Why not take a lil walk down to you're local TV repair shop, or a car park where ppl dump stuff, and see if you can find/ borrow/ steal etc a flyback transformer from a nice big old wide screen TV. Should give you a lot better performance, and probably a lot more control of how much voltage you're playin with. Only down side is that you might be able to get into the really really lethal voltages, and give you're self one final zap before snuffing it. I would suggest avoiding that, as it severly curtails you're enjoyment of your nice new HV supply.
    Jaz_knos
  10. Moriquendi
    3 Nov 2005
    He already has a flyback, we're discussing how to drive it to get a variable output voltage.
    Moriquendi
  11. JazX101
    27 Jun 2004
    Ah, reet, probably a bit more reading of the other stuff in the thread would have been helpfull here!
    Would it not be possible to alter the flyback voltage by varying the couplance between the flyback and the main coil? would mean you could have a nice simple stable power-supply and just adjust the one thing??
    If you're puzzling about the light switch dimmer thingie, why not try it at a low voltage, just too test. Worst that happens is you dont get it to do anything, which means it either doent work or you have a dud coil.
    Jaz_knos
