Simple as, I need to build an ON/OFF and Reset Switch for my PC. Can I combine this... http://www.ebay.co.uk/itm/Reset-Pow...ltDomain_3&hash=item19bfa873ad#ht_2122wt_1172 With this... http://www.ebay.co.uk/itm/Nickel-Pu...Supplies_ET&hash=item230aa9152a#ht_2248wt_914 For a Reset Switch. and then this... http://www.ebay.co.uk/itm/mATX-ATX-...nectors_RL&hash=item27c37c2d24#ht_1211wt_1172 With this... http://www.ebay.co.uk/itm/Metal-LED...Supplies_ET&hash=item27c336d846#ht_500wt_1415 For a Power Switch!
Yes. If you're going to have them both visible on the front, perhaps do a 16mm bulgin for reset, and a 22mm for the power. Might look a little nicer for them to be the same thing.
Thanks for the green light guys. I'll try the cheaper Reset Switch first. It'll be housed in a bare bone 690 II chassis which is destined to be water cooled... http://forums.bit-tech.net/showthread.php?t=226693&page=2
