Hardware Building Dream HTPCs: Steiger Dynamics Interview
Discussion in 'Article Discussion' started by Meanmotion, 16 Jan 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Jimbob
    Jimbob Minimodder
    2 Jul 2009
    Nice looking units, but IMO a HTPC should look more like a DVD Player or Hifi amp so it blends in with your other devices. One of my favourite looking units was the "Acer iDea 500" I bought a Moneual Moncaso case recently but I noticed they have pulled the plug on those now.
    The big problem with HTPCs is that a persons requirements vary, I have very little storage on mine (120GB SSD) and 4 tuners, where others wmay want a large GPU for gaming use too.
  3. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Nice article. I think the case looks pretty interesting (although it is a bit on the large side) and the LCD screen looks really nice.
    I see that the latest issue of CPC has a review of the case - are bit-tech planning on reviewing it too?
  4. Meanmotion
    16 Nov 2003
  5. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Ah, somehow managed to miss that! Cheers.
  6. runadumb
    runadumb What's a Dremel?
    20 Jan 2010
    Its a nice case for sure but the SG04 looks good enough for me.
    I looked up the review you linked to, any news on the new couch master?
  7. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    I hope they get round to making a smaller, slimmer version too. I understand that they then wouldn't be able to fit WC gear etc in, but I can imagine there are many out there who like their design but just can't fit something that large in the living room. I actually really like the design they chose, it's both bold, genuinely understated and elegant thanks to the mixture of curves, hard lines and excellent material choices. Aluminium has that great ability to look neutral in both modern and more period environments, unlike the standard black box look that Silverstone recently chose for their new HTPC case. That other one just looks like a VCR from the 90s, no way would I want it visible at all, which is a wasted opportunity to be honest.
    This case looks pretty similar to many high end audio setups, which I quite like. Obviously it's not that exciting, but it's got a nice balance to it. A thinner profile option would be cool though, although I can see the appeal of just having one on show, if only there was enough space to do so.
  8. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    The SG04? You mean the case that looks like a portable shredder? Each to their own I guess.
    As for the case, I'm not a fan. It looks too much like an oversized cassette deck from long ago.
  9. jrs77
    jrs77 Modder
    17 Feb 2006
    If I'd be thinking about building a HTPC in such a big expensive case I'd probably go for the OrigenAE S21T, which has a built-in 12" touchscreen.
    The case pretty much looks the same, besiides the TFT.
  10. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I'd actually love to see a smaller version of the LEET Reference case that was about the same height as a hifi amp. 22cm tall is far too big for most people, and although I get that having a really big case allows for a wider range of hardware and watercooling options, it's far too big for my taste. You could slim it down with a smaller LCD display, and a slot-loading optical drive (or better yet, no optical drive?)...
  11. runadumb
    20 Jan 2010
    DOH! I meant the SG08
  12. SchizoFrog
    5 May 2009
    Ahh... That makes a lot more sense. :)
  13. Nexxo
    23 Oct 2001
    Watercooling for an HTPC? Overcomplicate much?
    Personally I prefer my HTPCs lean: passively cooled, low power consumption. It is a device that should be able to run quietly, 24/7 with virtually no maintenance and small electricity bills.
  14. jinq-sea
    15 Oct 2012
    I thought that. You're a fellow HFX owner aren't you, Nexxo? For me, that's the pinnacle of a brilliant HTPC. I've got the Classic, and I love it. Had it for years, and it's had a number of systems in it!
    EDIT: For those not in the know, one of these.
  15. blackworx
    blackworx Cable Wrangler
    31 Jan 2008
    No sh*t, Sherlock!
  16. Nexxo
    23 Oct 2001
    I am indeed. For me they're one of the few HTPC cases worth considering. Go passive or go home. :thumb:
  17. jinq-sea
    15 Oct 2012
    I recently rebuilt mine - I should do my build log really!
  18. BlackRaven
    BlackRaven Freaking printers!
    20 Feb 2010
    These guys can cram a lot of kit in to that box. For example:
    Processor:
    AMD FX-9590,
    5.0 GHz Turbo
    , 8-Core CPU
    CPU Liquid Cooling:
    LEET™ Custom Liquid Cooling for CPU and graphics
    cards, co-developed with Swiftech
    Graphics Card:
    2x AMD
    Radeon R290X
    in CrossFireX
    GPU Liquid Cooling:
    EK Water Blocks EK-FC R9-290X HP full-cover water
    block with black fittings
    Motherboard:
    ASUS
    Crosshair V Formula-Z
    Motherboard, AMD 990FX
    Chipset
    Memory:
    Kingston HyperX Beast
    32 GB
    2133 MHz Memory
    Power Supply:
    Seasonic Platinum
    1000 Watt
    Power Supply
    LEET™ Custom Power Supply and Drive Cabling
    Drive 1: SSD -
    Kingston HyperX 3K
    240 GB
    Solid State Drive
    Drive 2: SSDH
    – WD Red Storage
    16 TB
    (4x 4.0 TB HDDs)
    Tubing:
    UV-reactive semi-transparent tubing (1/2 x
    ¾
    ) with white Ice Dragon
    Nano Cooling fluid
    Optical Drive:
    Asus BW-12B1ST
    Blu-ray
    Rewriter
Tags: Add Tags
