Build Advice Building my first PC
Discussion in 'Hardware' started by lolscourge, 25 Aug 2011.
  1. lolscourge
    lolscourge What's a Dremel?
    25 Aug 2011
    I'm building my first PC (with help) and I just want to make sure I've got my money's worth (budget £600) and that all these parts are compatible. Also if there's anything else I'd need or need to change (fans? PSU?) then that'd be great
    Motherboard
    RAM
    CPU
    Graphics Card
    PSU
    Case
    HD
    CD Drive
    Thanks for any advice :)
  2. lolscourge
    25 Aug 2011
    I'm going to go ahead and bump this because it sunk to the second page pretty sharpish.
  3. oliverrr
    oliverrr What's a Dremel?
    24 Aug 2011
    All the Build seems fine to me, but why get the i5 2500? not the k version, any reasons?
    Also i'd change the case to something like a antec one hundred and maybe change the mobo to a msi p67a gd53. but apart from that it all looks good. :)
  4. dave99
    dave99 What's a Dremel?
    26 Jan 2011
    I would also go for the i5 2500k, it is only a few pounds more but will give you a much longer life than the vanilla 2500 due to the overclocking headroom. Overclocking is no longer the preserve of the hardcore user that it was, it is really simple and makes a huge difference. I understand that people will often suggest spending more but in this case it is well justified.
  5. jones2636
    jones2636 What's a Dremel?
    8 Sep 2011
    All seems fine but I would maybe think about upgrading the cpu to a k series. I think your case would be fine but the spec looks nice.
  6. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    The RAM definatly not fine.
    Single channel. You want dual.
    I would reccomended buying computer hardware on a site like
    http://www.scan.co.uk/
    Better prices and superior support if you need to return a faulty.
  7. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Do you need to include a copy of windows in the price?
