Other Building my own computer
Discussion in 'Hardware' started by dabillin6283, 25 Jun 2011.
  1. dabillin6283
    dabillin6283 What's a Dremel?
    25 Jun 2011
    For right now all I know want for sure is to use the i7 2600k to build my system around. I really want to overclock it as well. I have been thinking about a ASRock P67 EXTREME4 for my motherboard, but not sure. If yall have any suggestions for other motherboards, grahics cards, memory, cooling systems, and power supplies. I'm trying to keep it at about $1500-$1750.
  2. donok
    donok Every Little Helps .....
    16 Feb 2011
    Get a Msi p67A-GD53. Its great for overclocking and is a good price. Also if you don't need hyperthreading then get an i5 2500k. Get 8gb corsair low profile 1600mhz. Psu I would get a corsair ax model as they come with nice black cables. Graphics would depend on your monitor(s) and what games or software you wish to use. Also a 120gb OCZ vertex 3 solid state drive.
  3. donok
    16 Feb 2011
    Motherboard, CPU and memory is $446 on newegg.
    Then pick a case, tell us what resolution your monitor is and what games you play or software you use and we can Reccommend a gpu and a relevant power supply. After that it's just add the ssd which is $250 and a Asus xonar ds soundcard for $50.
    That's $746 without case,graphics or power supply.
    Or
    If you really need the i7 2600k then it will cost $826 so far.
  4. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    I'd try and get something like this, as donok said if you don't need the hyperthreading maybe change to the 2500k, and get a gtx 580 instead, or up the board to something like the asus p67 sabertooth, also i had no idea if you needed a monitor/keyboard/mouse, so left that out and just built you a system, hope that helps
  5. Deders
    Deders Modder
    14 Nov 2010
    I wouldn't recommend Asrock based on my previous experience with 2 of their boards.
  6. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    As above, Asrock are a budget brand trying to do enthusiast builds. From what I've read it works well but not as well as your ASUS or Gigabyte boards!
  7. Torlin
    Torlin What's a Dremel?
    25 Jun 2011
    check of Compatibility
    Hey guys, since im new to this i was wondering if you guys could help me double check if these are compatible, also will either the monitor or the tower come with cords to connect to each other?
    also i was thinking about downgrading the cpu, any suggestions?
    -A455-5028 ::Asus DRW-22B3S/BLK/G/AS 22x Internal CD/DVD Drive - DVD±R 22x, DVD+RW 8x, DVD-RW 6x, DVD±R DL 12x, DVD-RAM 12x, CD-R 48x, CD-RW 24x, E-IDE(PATA), 2MB, Black(1.8 lbs)
    - H54-2206 ::Hyundai Q226LD 22" Class Widescreen LED Monitor - 1080p, 1920 x 1080, 16:9, 10000:1 Dynamic, 1000:1 Native, 5ms, DVI-D, VGA, Black, Speakers(10.7 lbs)
    -P56-0460 ::pNY VCGGTX4601XPB-OC GeForce GTX 460 XLR8 OverClocked Video Card - 1GB GDDR5, PCI-Express 2.0, Dual-DVI, HDMI, SLI-Ready, DirectX 11(2 lbs)
    -C283-1187 ::Cooler Master RC-932-KKN5-GP HAF 932 Advance Full Tower Case - ATX, Black, SuperSpeed USB 3.0(34.5 lbs)
    - A455-2937 ::ASUS M4A89GTD PRO/USB3 Motherboard - AMD 890GX, AM3, DDR3, USB, RAID, ATX (3.5 lbs)
    -A79-1965 ::AMD Phenom II X4 965 Black Edition AM3 CPU HDZ965FBGMBOX - 3.40GHz, Socket AM3, 6MB Cache, 2000MHz (4000 MT/s) FSB, Retail, Processor with Fan(0.6 lbs)
    - T13-1106 ::Coolmax CUG-950B 950-Watt Power Supply - ATX, SATA-Ready, PCI-E Ready, Modular(7.6 lbs)
    - YYD1-TW3X4G1333C9DHX ::Corsair Dual Channel 4096MB PC10600 DDR3 1333MHz Memory (2x2048MB)(0.4 lbs)
