Build Advice Building new gaming PC (£1200)
Discussion in 'Hardware' started by pottageb, 3 Jun 2009.
  1. I-E-D
    I-E-D Minimodder
    28 May 2009
    I'm planning an i7 build, for about 1k, and earlydoors is pretty much it. if you do spend 1 grand, you could always spend 200 quid on watercooling?
  2. DarkBanana
    DarkBanana What's a Dremel?
    6 May 2009
  3. pottageb
    pottageb What's a Dremel?
    3 Jun 2009
    Thanks for the replies, does this look like a good build?? Will 850W accomodate it?
    Ben
  4. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Yeah, 850W should be more than enough. That setup looks pretty solid to me. :)
  5. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    is there a reason why you are getting an ecogreen drive? is it the quiteness? the noraml F1 drive would give you better performance
  6. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    They are cheaper atm.
  7. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    But they are very slow.
  8. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    i wouldn't say very slow, but i would still change it to a normal spinpoint.
