Cases Built in Utgard fan controller not working
Discussion in 'Tech Support' started by Sponge12349, 28 Aug 2010.
  1. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    My Xigmatek Utgard Case has a built in fan controller. 2channels each with connections for up to 3 fans. I think i have connected the molex connector properly although the wires seem to move around (inside the bit at the end) and it is hard to connect to my power supply.
    Ive tried booting the computer with the knobs turnt down low, up high and in the middle.
    Whatever I change nothing happens to any of the fans. :wallbash:
    What could i be doing wrong or do you think there is a fault with the case?
    Thanks
    Sponge
  2. NeiltheDruid
    NeiltheDruid Member
    20 May 2009
    If you are sure you have everything connected up as it is supposed to be, there could be something wrong with the fan controllers circuitry. Try various molex connectors from your psu.
