Scratch Build – In Progress Bulldozer project - AMD Tribute
Discussion in 'Project Logs' started by BaxterTheFly, 9 Apr 2015.
  1. BaxterTheFly
    BaxterTheFly What's a Dremel?
    8 Apr 2015
    It started to get final form, if you guys thought it looked big before, wait to see it now :D
    ITS MASSIVE!!!
    Still, much more work to be done :D
  2. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Looking good.
  3. BaxterTheFly
    8 Apr 2015
    Ok, i know it has been a good long while since i last posted but i am happy to inform you that i am contiunuing my work and that i cleared another year in my faculty :D studying came first to this... sorry :(
    I took few of these at local shop here in Serbia ( Uradi sam / Do it yourself )
    I cut them to lenght and i made new tracks...
    ( mind the dog, she is dangerous ) :D
    I figured out how to make the windscreen the way i want it to be, also spoon is done tomorrow when i take the rear suspension from Fiat Punto
    There is a bit more update some stuff came last week from AquaTuning :)
    Tomorrow i will make ubber update!!! I kept you in the dark for far too long :)
  4. Dr. Coin
    13 Sep 2013
    I found myself mentally making truck noises while looking at the pictures.
  5. BaxterTheFly
    8 Apr 2015
    Wroom Wroom :D i will put little speakers that will make sould like this while booting in to windows
    https://www.youtube.com/watch?v=eFl2ga4hlFM
  6. BaxterTheFly
    8 Apr 2015
    Ok, i got few pics of progress and a question :D
    The spoon will be simmilar to this but i will str18 it a bit, add some mesh on top, make it more robust with stirofoam and such... it will look really good with suspensions and all painted ;) trust me, i have it in my head!!!
    Also there is a question regarding these two pictures below
    Should i make mud protector on the 2nd pic, or should i leave it like it is on the 1st?
    Please post coments on what you think i should do and what you like/dislike on it...
    Tnx, Bax!
  7. Dr. Coin
    13 Sep 2013
    I perfer this version.
  8. BaxterTheFly
    8 Apr 2015
    I made a compromis with mud flaps and went llike this, i think you will like it :D
    And the demonstration of power!!! :D
    Just for you to see how sturdy this thing really is... ( also to mention i am 192cm tall )
    I hope you can gasp the sheer size of this thing :D
    At some point i will make it battery operated and i will drive on top of it XD
  9. BaxterTheFly
    8 Apr 2015
    Peeps, i know pictures are awful but my camera bateries ran out :( so i had to use my camcorder.
    I know most of you will criticize my choice to go for wood instead of alu but i had my own good reasons :)
    Also as you can see, my suspensions came and i am super happy about it :) Deatails almost complete and i hope that tomorrow i will finish complete body and start painting it hehe
  10. BaxterTheFly
    8 Apr 2015
    here is an update after a big long while
    I fixed the doors so they can open correctly now and i had to make them open up top because of clearance issues :/
    This is first layer of acrylic filler
    This is 2nd, and there might be a tird to fill the smallest holes :)
  11. BaxterTheFly
    8 Apr 2015
    I've got some stuff inside of the case just to check how everything fits and looks in the cabin :D
    I hope you like the overall look inside the cabin :) its a bit tight but I like it like that :) only main ssd's will be inside the cabin, hard drives will go under the entire thing, and under that, radiators, pumps etc :D
    Its nearing the end and the start of painting :) i cant show you enough how that makes me feel :D
    Also a small adition to everything :) i fixed my speakers that i will be using and i will be also replacing the monitor with 40" 4k display :D
  12. BaxterTheFly
    8 Apr 2015
    A few more days left, I will finish the mod before August :D
    As i didnt want to post pictures that make no sence, posting pictures where only i could see the difference, i waited a bit and once i had done things i deem'd made a change, i made a little walktrough around what i have done and around the case...
    The video is a bit on the longer side, and i got a bit confused with terminology i would be thrilled if you'd watch it :)
    https://www.youtube.com/watch?v=XweUbD1jcVo&feature=youtu.be
    I will grab some batteries for my camera and that is one of the reasons i used camcorder now, and i will take some nice closeups tomorrow, also i will most likely put primer on the drawer piece :)
  13. BaxterTheFly
    8 Apr 2015
    UPDATE!!!, still not painting :( ran in to some work related issues :p but still sort of big update :)
    1) The "Nose job":
    2) FINALLY! Fan mount...
    3) Polyester filler :
    Hole for 24-pin done old fashion little plate style with |-type screws :D
    It still needs sanding before painting, i corrected the edges and everything on the bodywork of the core part, i got fittings, and i did a hole for 24-pin
  14. Dr. Coin
    13 Sep 2013
    I like the hidden fan ports. Case is looking good.
  15. BaxterTheFly
    8 Apr 2015
    Here is one long overdue update.. bodywork is taking much longer than i anticipated
    I ended up saving me the trouble with doors that open like this.. so the original idea --- to the water
    Made my life allot easier when it came to cooling :D fans can now be securely mounted to the side pannel XD
    Also, now everything seems to fit perfectly >.>
    And some finishing bodywork, tiny air bubbles gave me allot of problems after sanding...
    In the end it was worth it... Just perfect :D
    Also, one more idea that took me, Idiot, almost entire day and it was complete bust!
    Also, i figured that if i paint over the dry body kit, it will give it a bit of strength so i ended up doing that and it made my life easier, I paint it when i am done, and than, when i am back from work tomorrow its nice and solid, doing this saved me from allot of scratches :D
    The back fan mounted ( the one that cools the back of the socket ), i must add that when i did measurements for the cuts, i wanted to make it octagonal, i kind of dig the lines.. i think i will pinstripe them on it... Also the fan is mounted to the plate, that is than mounted to the case...
    Checking if the cables fit the hole i made, it will be awesome when i put the sleeved cables there with cable combs there :D
    There, I hope you guys like the progress i made, i will take liberty to say that it the case as a case should be done in a week, and the water cooling components and components should be fixed inside few weeks after that total...
  16. BaxterTheFly
    8 Apr 2015
    Been a while since i posted, and loads of things happened since than :)
    Enjoy the slideshow XD
    Top part still needs some minor adjustments, it now opens quite nicely with some support from suspensions :)
    I dont know about you, but it looks more massive than it used to :)
    Next in line is the finished front piece remaster!
    next, experimenting with paint/foils :D
    Here you can see how the roof holds with suspensions when open :)
    And the last, i really think you will like it, 95% finished product XD
    Bare in mind that the foil didnt set as it should have, and i will re-do it, the glue needs to be heated and i didnt have good dust free chamber, i redid it and the finished pictures will be out soon, only thing left for me to do now is fill it with components :), loads of little details finished as well, this is just a preview! Finished pics will come out when i have it all working!
  17. BaxterTheFly
    8 Apr 2015
    Hello guys and really sorry for not updating, i have had some massive lack of time so i didn't get to do anything that i wanted. This is a little tease and i promise i will post full update log once i get time to work on it ;) . Also, tomorrow is the day i fire this thing in its cage as i have been running the system hihihi.
    So here it is for now:
    Brm brm brrrrrrmmm
  18. Cheapskate
    13 May 2007
    Much cleaner.:thumb: It looks bigger from that angle.
  19. BaxterTheFly
    8 Apr 2015
    Actually it is smaller but the rotation of the board changed :D its laid down now ;)
  20. BaxterTheFly
    8 Apr 2015
    Ok, some things i think you are gonna like that has been done to the mod :D
    16mm Copper tubing:
    Changed the board rotation, its laid down now:
    Added professional grade backplane ;)
    And the drawers:
    and the look before painting from different perspective:
    Also, the 480EKWB rad with 8x CoolerMaster Jetflo:
    New ones come tomorrow, enjoy!
