CPU Bulldozer Quirks, (Documention of,)
Discussion in 'Hardware' started by .//TuNdRa, 5 Feb 2012.
  1. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I figured I may as well start documenting all the little quirks and issues I'm having with bulldozer, as well as the fixes, so if anyone else is silly enough to follow me down this road; they shouldn't have quite so much trouble, as well as throwing questions out there to the few who were crazy enough to buy an FX chip as well.
    1. Processor Underclocks at Load!
      This is because of the wonderful little tidbit AMD threw in to stop the CPU from melting under bad cooling; "Hardware Thermal Control", it's a setting in the Bios. Disable it if you dare, generally kicks in at about 55 degrees, so you'd need a legendary cooling system to keep it below that, or low clocks. Generally; Bulldozer is happy, in short bursts, at anything up to 70 degrees in benchmarks.
    2. Processor randomly drops clocks in some tests, despite being at a low temperature!
      The little brother to Hardware Thermal Control, Application Power Management, it'll drop the clocks in torture tests such as Prime95 to stop the processor from overheating. I'm a bit mixed on this one, as it does keep the heat down very well, and seems to make overclocks require less voltage, flipside is; performance will not be fully represented in tests. I'm running with it off, despite the fact it demands more power to get 4.8 stable.
    3. Games don't work!
      Bios issues. Seems to occur only with Steam games. Update to the latest Bios for the board and move on, Validate steam files too, I had this Issue with Saints Row: The Third and Portal 2 for a while, but solved it by updating Bios and validating files.
    4. I updated my bios, now half the cores have vanished!
      I've only observed this on Gigabyte motherboards, but it's a simple setting in the Core Unlocker; "One core per FP unit", disable it and move on. The slight FP bonus from leaving it enabled isn't enough to make up for the loss of 45% of the horsepower.
    Interesting thing is that Hardware Thermal Control and APM are separate from Cool & Quiet, you can leave C&Q running if you so choose and not suffer any issues from it, although it may cause instability if your Overclock is tetchy to begin with, as errors can occur when switching the processor between the power states.
    This is only observed on my Gigabyte board, so you may have other issues, or the settings might not be called quite the same thing. Post up the question and I'll do my best to give you a hand with it. I know most things can be resolved pretty easily.
    I'll keep adding to this as time goes on and i find little quirks and issues. Those are the only large ones.
    Please try not to troll this. I'm aiming for it to be helpful for anyone else that buys Bulldozer, not a list of its failings.
  2. Wozza365
    Wozza365 What's a Dremel?
    26 Jan 2012
    Apart from number 3, i havent seen any of these problems, and i have a £40 air cooler and my CPU hasn't even hit 50c on prime in a warm room
    These are just the downs which seem to be the only thing considered when people are buying it, there are also lots of advantages as well, one of them of course being that it is cheaper than an i5 and also much easier to overclock than the standard i5 2500
  3. .//TuNdRa
    12 Feb 2011
    I noticed it mostly because I'm usually overclocking. At the moment I'm pushing towards 5Ghz stable, although I think i'd need some better fans on the Rad before I'll get there, APM really has a massive impact on heat, I gained an extra ten degrees by disabling it, as well as needing a touch more voltage to get this stable, but it's also a fair boost in performance from disabling it, rule of thumb; if its using all the cores, and it ain't fast enough; try turning APM off.
  4. Tangster
    23 May 2009
    Have a couple of 5500RPM deltas in my desk drawer. You can find them for ~£15 each on ebay.
  5. Wozza365
    26 Jan 2012
    for your rad, id recommend Coolermaster Excaliburs, they have really high pressure which is ideal for rads, or Akasa Vipers/Apaches, both provide awesome amounts of airflow
    Why does everyone here overclock? I don't understand, most programs don't even need the extra power, games certainly don't
  6. .//TuNdRa
    12 Feb 2011
    Because I'm desperately trying to outpace all of the 2500Ks in the Geekbench thread. I'm getting there. Slowly. Plus I tend to Handbrake Encode stuff reasonably often, and that really responds well to the extra speed.
  7. Wozza365
    26 Jan 2012
    why didnt you get an 8150 then?
    you'd have already had a head start in clocks
  8. .//TuNdRa
    12 Feb 2011
    Because there's very little difference between them, I need an extra 0.07v in most cases, Its only when you start to push past 5ghz odd that you have to worry.
  9. Tangster
    23 May 2009
    I don't game very often. My overclock is for 3D rendering and video encoding. It's also setup so when it's not under load it drops the clocks to 1600MHz and drops the vcore as well.
    Getting there. Our lead is only ~600points now. You'd be kicking us if BD had a half decent memory controller.
  10. murraynt
    murraynt Modder
    6 Jun 2009
    Maybe it's time to send the board back mate?
  11. .//TuNdRa
    12 Feb 2011
    It's a Processor related feature. And those are AMD spec, all of it. It all works now, anyway.
  12. feathers
    feathers Minimodder
    11 Apr 2009
    Depends what games u play.
    FSX with addon scenery none of the current desktop processors can handle fully.
    Arma II is very CPU intensive. High performance GPU's need a lot of feeding and so you generally find you don't get max performance from the GPU until your overclock your CPU. The point at which the FPS stops increasing is the time your cpu can keep up. I haven't tested this on i5k actually but I remember a few years ago getting a big increase in FPS when I overclocked CPU.
    I can see the difference even in windows. Everything is faster and snappier when the CPU is overclocked. Going to 4.4ghz I could see the difference, then 4.8, then 5ghz.
  13. AoE
    AoE What's a Dremel?
    4 Oct 2011
    feathers buy a saitek yoke for fsx :), knock realism up full and learn how the FMC, then you'll truely experience fsx, thats if you wish to fly commericial aircraft
  14. feathers
    feathers Minimodder
    11 Apr 2009
  15. AoE
    4 Oct 2011
  16. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    Apologies for 'slightly' trashing an AMD thread.
    But in answer to your Question Wozza, (that name come about because of iwoz, by any chance?) Because its fun :D
    & To beat pookey in geekbench.
    and on a more releated note, tundra, do you think it's just the memory controller holding bulldozer back really, would a whole new socket help AMD as well? I just don't understand why they keep sticking with pins on the CPU instead of a LGA socket, I know they try to do it to allow AMD users to keep there CPU's interchangeable, but surely that philosphy goes a long way towards hindering them from competing with intel, obviously they haven't got the resources of intel, but I reckon if they hadn't made AM3+ boards backwards compatiable (they aren't they?) Which would have allowed them to hopefully use a better memory controller, the BD chips would be pretty darn good in single & multi threaded task's
  17. law99
    law99 Custom User Title
    24 Sep 2009
    So the next chipsets should be fixing memory performance right? It seems like you should be competing with the I7 2600ks rather than 2500ks.
    Hopefully when they sort out some of it people will not be so negative about it.
    Also, for wozza, i definitely see a performance increase in usage day to day in the short time I've had my 2500k. Plus I regularly backup my dvds, and there's only so much time I want to not be gaming for :)
  18. .//TuNdRa
    12 Feb 2011
    The socket isn't helping matters, but what's really buggering it is the NorthBridge. There's a massive Bottleneck in there, but the Memory Controller most definitely does not help performance. With a good controller, lower Cache latencies and the ability for the decoder unit to feed six threads instead of four would go a long way. It'd mean three threads per "Core", same as the Phenom IIs, rather than Two.
