[Bundymania User Review] Microcool Benchtable Banchetto 101 Modular
Discussion in 'Watercooling' started by bundymania, 2 Jan 2012.
  1. bundymania
    bundymania Bastelorakel Industries Worldwide
    4 Jun 2009
    Hello Guys,
    Today i would like to give a short overview of another Benchtable (In the past I did some reviews of Benchtables from other producers). Therefore I would like to present the current Version of the Banchetto 101 from Microcool. Microcool has its residence in Italy and has got many fans because of their well products. I am using the older version for two years and I am very satisfied with this product (I think have changed the installed components about a thousand times). The Banchetto 101 is made of a metal-arylic-glass-mix. The parts which are made of acrylic glass have an adequate material thickness of 8mm. They do not show any defects or errors during often usage. In comparison to the older version, the version current version in this review has two additional holes for water-cooling tubes, led-holes at the backside and the acrylic glass is dark toned.
    Technical Details:
    Modell: Banchetto 101 Modular
    Seize: 400(L) x 350(W) x 362(H) mm
    Weight: 5.3 Kg
    Material: Acrylic Glass (8mm), Aluminium, chrom-plated steel screws
    Colour: transparent, black, chrom
    Motherboard compatibility: ATX & Micro ATX
    PCI Slots: 7
    5.25" Bays: 3
    3.5" Bays: 4
    PSU bay: Standard ATX PS2
    Water-cooling: prepared 360 Radiator, Pump & Reservoir
    Optional Fans: 4x92mm
    Price: ca. 220 Euro
    The Banchetto 101 is a construction kit, which is shipped in a big box. All single components are well packed in small boxes and wrapped with bubble-warp. Therefore they are very well protected.
    The assembly instruction has many pictures and is written in English language. The assembly is quite easy (maybe depends on your assembly knowledge) and should be finished around 45 minutes or 1 hour. The whole assembly procedure requires an Allen key and a standard screw driver. The Banchetto 101 offers two different assembly options, which are shown in the following pictures.
    The assembly procedure is preponderant done with knurled screws in two different sizes. The scope of supply does not contain screws for power supply and device assembly.
    For the optional installation of max. 4x92mm Fans, you have to install the following plates:
    The base plate, intermediate bottom and the motherboard-tray are built of 8mm dark toned acrylic glass. The separate plates are equipped with threads of screws.
    The motherboard-tray is easily installed with 4 rubber stands on the middle plate without any screws. Therefore you can easily lift the upper plate to the side, if you want to do a “quick-change” on your installed hardware. The motherboard-tray has as well a cut-out under the CPU-Socket, which means you do not have to disassemble the motherboard, if you like to switch the cooler.
    Reset- and Power-Switch are made in a robust „bulgin-style“ (cables of the switches are sleeved). The switches shall be installed under the motherboard-tray.
    The components for the installation of the other parts (drives, power supply, radiator, pump, etc.) show a high class processing quality (the assembly is done with knurled screws). The Banchetto 101 stands on massive rubber foots, which guarantee a save standing and fulfill an anti-vibrational function.
    Additional metal-bars stabilize the carrier plate.
    The sides offer conveniently two holes for watercooling-tubes. In my case you can see the usage of a 16/10 mm tube (3/8”-5/8”). The middle and the upper acrylic carrier plate offer holes in different sizes for a comfortable wiring of your PC components. The Radiator-blend has as well holes for the cables of the fans. The usage of slotted holes allows you to install a great variety of different Radiator types (the broadness of the Banchetto 101 allows max. 360 Triple-Radiators). Radiators which are bigger than 360 will overhang side wards.
    The seperate plugin-cards are fixed by thread-bars and knurled-screws.
    At the end i would like to present to you a few pictures of the older version, which differs slightly from the current version.
    Conclusion:
    All in all the Banchetto 101 Benchtable from Microcool from Italy is a very good product!
    The processing quality is on a continuous high level and the usage of different materials is well chosen. The price is – according to the quality of the whole package – on an adequate level. Nevertheless the acrylic glass is quite sensitive concerning dust and scratches. A few details like the decoupling arrangement of the drives and the assembly screws for the power supply could be improved, but this should be only mentioned on the brink. Because of the stylish design the Banchetto 101 can be used as a Benchtable or a replacement for a common PC case. If your purse offers (or your wife ;)) enough money and you prefer products, which are made of metal, you can acquire the aluminum version for 370,00€.
    Thanks: I would like to thank the following companies and producers for supporting my review: Aquatuning, Phobya, Microcool, Bitspower, Noiseblocker, EK Waterblocks, Swiftech, Fractal Design and Aqua Computer
