Burn ISO
Discussion in 'Tech Support' started by Fozzy, 18 Apr 2007.
  1. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    I have an ISO of Vista ultimate that I want to use on a secondary HD. What I'm wondering is how I should go about burning the iso onto a DVD. I have the burner DVD's and numerous software but since it is an iso and an operating system i'm wondering if there is a special way to do this
    software I have:
    Nero 7 Premium
    Isobuster
    Xlisoft
    Western Digital Data Lifeguard tools
    WinRAR
    Windows XP burning utilities
    please help me : )
  2. Krikkit
    21 Jan 2003
    Use Nero to open the .iso, put a disk in the burner, and click "Burn".
  3. DougEdey
    5 Jul 2005
    In Nero standard program (i.e. non smartstart, non express) Goto Recorder -> Burnimage
    From Smart start -> Backup -> Burn Image
  4. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    could use imgburn, its free, great, and really good :)
  5. Fozzy
    25 Jan 2005
    I used IMGBurn and that program rocks. Vista is pretty damn sweet too. I need to pick up another gig of ram though before I try to game on it. Running Firefox and 7 widgets is putting me at 73% ram usage with a gig of ram. Depressing. Oh well I still have XP on my other raptor so I won't worry about it until I upgrade. But when I do I'll put Vista on Raid 0 and get rid of XP all together.
  6. krimson
    krimson What's a Dremel?
    16 Nov 2006
    most common cd authoring programs will burn iso's
    they are images of disks.. one of the most common mistakes people make is burning the iso right to the disk, thus having a cd with a .iso file on it.
    using neros "burn image" like dougedey said will set you right up.
    but, beware installing vista on a second hard drive!!! if you ever choose to not use vista anymore, you will always have the OS choice screen! (unless you use a booting utility that can wipe that) its not that big of a pain, its just annoying.
  7. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Editing the boot configuration ie. boot.ini should suffice in not having the boot loader asking all the time.
  8. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Vista doesn't use boot.ini so that doesn't work.
  9. Spaceraver
    19 Jan 2006
    So it overwrites the XP bootloader, pop in the XP CD and log in to recovery console. from there on fixboot should do the trick
  10. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Yeah, that works.
