Modding Burnt Case look
Discussion in 'Modding' started by crash32953295@msn., 19 Aug 2004.
  1. crash32953295@msn.
    crash32953295@msn. What's a Dremel?
    2 Aug 2004
    Hi im trying to creat a burnt case look as the theme for mine is inferno, ive got all t he lights in the hardware works and now i want to make some more of the case, its already been srayed with grey under and lightlly kinda speckled prayed with black on top.
    If any one has any ideas on how i can make it look more burnt and singed using paint, or could i use real fire :idea:
  2. funkymunky
    funkymunky Guest
    oxy acetaline would prob give u that burned look... followed by a coating of clear varnish i fink
  3. rankie
    rankie What's a Dremel?
    12 May 2004
    if you want a burnt look than just set the thing on fire :clap: , then cover with clear coat or somthing to protect it
  4. Leevi
    Leevi What's a Dremel?
    28 Jul 2004
    clear coat will ruin the look :blah:
  5. fieroloki
    fieroloki What's a Dremel?
    3 Jan 2004
    You can get a no gloss clearcoat. Its called a sealer.
  6. funkymunky
    funkymunky Guest
    *Drum Roll* :clap:
  7. Nova Kain
    Nova Kain What's a Dremel?
    23 Apr 2004
    Hehe, burnt PC's
    This is going to be Hot.
  8. Miirk
    Miirk What's a Dremel?
    26 Jul 2004
    Set that thing on fire!
    Getting a good finish prob is easier with paint though, you could use the rust-technique everybody is using for their HL2-cases but with different colors.
    It could be quite cool if you had a tft inside the case with a tv-fire (don´t know the english word) going 24/7.
    Ok, that might be to go too a little bit too far..
    Be sure to post some pics after you´re done!
  9. omicron
    omicron Baud.
    8 May 2004
    Ha ha ;).
  10. kobaj
    kobaj Banned
    4 Jul 2004
    get a torch or a big candle :D
    edit 200th post
  11. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
    Get some gas.. soak the case with it. Then set it on fire. Make sure you are at a safe distance.
    DISCLAIMER: I am not responsible for anythign that happens to you whe n you do this.
  12. Dash
    Dash What's a Dremel?
    24 Sep 2002
    Torch the sucker like this Melted Mac which still works lol
    EDIT: It was in a house fire I believe :hehe:
  13. kobaj
    kobaj Banned
    4 Jul 2004
    but its a mac how can it work
  14. Miirk
    26 Jul 2004
    :hehe:
  15. Emon
    Emon What's a Dremel?
    14 Jun 2004
    You can probably get a pretty sweet burnt look with a regular MAPP or propane torch. If you paint it first then torch the paint, it'll really look burnt. You could also set it on fire at this point, perhaps coat with a little lighter fluid. It's also probable that the fumes from the burning paint aren't very healthy, so do it in a well ventilated outdoor area and wear a respirator.
    You could also bang the **** out of it with a heavy hammer/small sledgehammer to get a hammered, burnt look like it just came out of a plane crash.
  16. clark.2004
    clark.2004 What's a Dremel?
    8 Aug 2004
    Ye i reckon Emons ideas is best just hit it with a hammer many times ahahaa :rock:
  17. omicron
    omicron Baud.
    8 May 2004
    Petrol + Case = Fire
    Just remember to take the components out first -- I doubt you'd be able to send your mobo back in a matchbox and claim incompetency of the manufacturer ;)
  18. crash32953295@msn.
    2 Aug 2004
    hey guys thanx for the feed bk, ive got a pick at the mo i can show u,
    But i didnt actually want to set it on fire, but i would like to use the paint affect to do this burnt look, as u can see my attemp sorta looks there. i could always get a blow torch ym dad has and make some scars down the side of it hehe.
    But preferablly paint would be good to use :D
  19. The_Gimpy
    The_Gimpy What's a Dremel?
    15 Jul 2004
    Back when I used to paint alot of minitures (its been a long time), I made a bunch of buildings that looked burnt down. What I did was using an airbrush painted burn marks upwards from windows and other openings. Becasue when you think about it, fire burns upward and the smoke rises, so I would suggest around your window to spray upwards along the edge. It would look like flames came out the window sort of like what would happen during a real fire inside your case.
    Edit: Check out the pictures on this page to see what I'm talking about Here
  20. hilmana
    hilmana What's a Dremel?
    20 Aug 2004
    well im sorry to start my first reply like this but dash quite frankly i dont really like the case :jawdrop: .
