Case Mod - Complete Butzi Tibute Porsche Ak MOD by warboy =IEM=
Discussion in 'Project Logs' started by warboy, 25 Jan 2020.
  1. warboy
    warboy Insane modder
    24 Nov 2011
    [​IMG][​IMG]
    I'm creating a PC inspired by the Porsche and by the racing world.
    There will be changes to the chassis, with custom loop, custom painting e custom part.
    Hardware Specs:
    Cpu: Intel I5 9600k
    Ram: XPG 32gb D41
    SSD: Intel p600 512gb
    PSU: CoolerMaster V750
    VGA: Msi Gaming Rtx 2080 ventus
    MB: MSI Z390 gaming pro carbon
    Custom Loop:
    WB: Masterliquid maker 240
    Waterblock VGA: ekwb vga
    rad: 360 ekwb se
    Pump: ek xtop revo d5 pwm plexi
    Tank: ek res x3 150 rgb
    I started by disassembling the case and replacing some parts with the chassis
  2. warboy
    24 Nov 2011
    To move the motherboard towards the center of the case, I insert reinforcements and cut the mobo tray
  3. warboy
    24 Nov 2011
    I continue to reinforce the chassis to create new openings.
    I seem to install roll bars. lol
  4. warboy
    24 Nov 2011
    Now I changes the support for the power supply.
  5. warboy
    24 Nov 2011
    we verify the spaces and continue the mod. We prepare the top case supports
    Cheapskate likes this.
  6. warboy
    24 Nov 2011
    Let's cut the frame to create an opening like the hood of a car .
  7. warboy
    24 Nov 2011
    I worked on the top to give them a racing style look
  8. warboy
    24 Nov 2011
    I add aluminum reinforcements to put the power supply in the front
    with an electric motor I want to give movement to a tank as if it were a piston of an engine.
    After painting the chassis, I created the lower plexy panel and I went on to test the "piston tank."
  9. warboy
    24 Nov 2011
    then I created the cover for the psu cables with plexyglass.
    and after i cut de front panel of the case CoolerMaster Sl600M
    I made the support to fix the radiators behind the mobotray
    and intstall the fans, and join the cables to make them custom-made
  10. warboy
    24 Nov 2011
    I took the engine cover of a porsche cayenne and used it to fix the plexiglass
    and now i prepare the hardware [​IMG]
  11. warboy
    24 Nov 2011
    and after assembling I airbrushed the other side of the case.
    [​IMG].
  12. warboy
    24 Nov 2011
  13. warboy
    24 Nov 2011
  14. Tech Cave
    Tech Cave What's a Dremel?
    18 Sep 2019
    an absolute work of art bro
    warboy likes this.
  15. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
    Fratello fantastico
    warboy likes this.
  16. warboy
    24 Nov 2011
    Many thanks ! BRO
    #scorpio
  17. Mizuwari
    Mizuwari In vino veritas
    19 Sep 2018
    I'm curious to know is the Cayenne still works :D And did you borrow the part or bought a new spare one? Very nice work, though. As usual :clap::thumb:
    warboy likes this.
  18. Cheapskate
    13 May 2007
    @Mizuwari -His neighbor will never notice anything wrong. He still has 7 pistons. ;)
    This looks cool. You always do great work, but wont they kick you out of Italy for making a German car tribute? :D
    warboy likes this.
  19. kim
    kim hardware addict
    10 Jan 2016
    absolutely splendid :clap:Italian modders are really great
    warboy likes this.
  20. Gian
    Gian What's a Dremel?
    14 Nov 2019
    Wow
    warboy likes this.
