CPU Buying a locked/unlocked Sandy Bridge
Discussion in 'Hardware' started by Spikey101, 11 Apr 2011.
  1. Spikey101
    Spikey101 What's a Dremel?
    24 Oct 2010
    Is it something to do with the multipliers? I can't find any info on it. Was planning on getting an unlocked as I heard they were better for OCing but they are all sold out on Scan which is where i'd like to buy from if possible. Ebuyer doesn't even have unlocked ones.
    I will only be OCing on air and im only a beginner so does it really matter that much to me? Thanks guys.
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Locked chips do not overclock at all
    Unlocked chips do.
  3. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
  4. derpooch
    derpooch What's a Dremel?
    11 Oct 2009
    You need the K for overclocking- the new chips are restricted to a base clock of ~100, and only the multiplier can be changed :)
  5. Spikey101
    24 Oct 2010
    Fantastic thanks guys, I see now. The OEM ones were the only ones that had unlocked in the name on the product. I didn't know about the K reference. Thanks a lot, means I can order my upgrades tonight now ;)
  6. murraynt
    murraynt Modder
    6 Jun 2009
    The k version is only 10 pounds more and they overclock like a champ.
    Well worth it.
  7. law99
    law99 Custom User Title
    24 Sep 2009
    Mmmmmm... K version. Special k.
  8. rob the bank
    rob the bank What's a Dremel?
    13 Mar 2010
    But remember it only makes a difference if you have a P67 motherboard as the H67 can't OC anyway.
  9. Kvothe666
    Kvothe666 What's a Dremel?
    14 Apr 2011
    as far as im concerned the only way to go is the unlocked 'k' models as they are the only ones overclockable. however DO NOT alter the base clock, the way to OC these is just via the multiplier.
