Modding Buying plexi/acrylic in the UK?
Discussion in 'Modding' started by jai_hou, 30 Jul 2003.
  1. jai_hou
    jai_hou What's a Dremel?
    30 Jul 2003
    Hi Ive just across the modding scene and a newbie so bear with me. I dont know if this has been posted before but I just wanted to know where the best place to get plexi from in the UK. Ive seen some in Homebase but it seems to be expensive and not much range. Thanks in advance
    Michael
  2. kong
    kong cnc-guy
    24 Feb 2002
    If you're using it for building a case, then stay away from the DIY stores - it is extruded acrylic they sell, and is no good for this. I got mine from a local acrylic fabricators, you should try to get cell-cast acrylic as it easier to machine, and you will get a better finnish on it. Just have a look through the yellow pages.:thumb:
  3. Clockworks999
    Clockworks999 What's a Dremel?
    20 Jun 2003
    I bought some 3mm acrylic sheet for just under £2 per square foot. Got it from a local plastics supplier. They sell mostly building stuff- fascia boards, guttering, etc.
    Cheers
  4. maeterlinck
    maeterlinck What's a Dremel?
    14 Jul 2003
    local industrial estates are great places - you'll find all sorts of useful stores.
    for metal then scrap yards are superb - you can't agrue with 60 pence per kg
  5. ST8
    ST8 What's a Dremel?
    14 Feb 2003
    b & q sell various sheets of polycarbonate (like acyrilic but a bit harder). I got a 4'x2' 1/4" for about 15-20 quid, which works out to be about 2-4 quid a square foot which aint too bad...
  6. Arien
    Arien What's a Dremel?
    22 Jun 2003
  7. Crim
    Crim What's a Dremel?
    1 Jan 2003
    thanks I've bookmarked that :D
  8. burnoutuk
    burnoutuk What's a Dremel?
    18 Feb 2003
  9. maeterlinck
    14 Jul 2003
    yeah the 4D model shop is a good place - they also have loads of other useful modding stuff like resins and tools etc.
    :D
